Digital2 Platinum 751G at BigLots 8G/dual core/1G ram/ 1024 x 600
    Happened to see this at BL last week. This is supposed to be "released" on 8/11 according to Digital2 support. $99. Notihing listed on the d2pad.info site.
    Anyone have any experience with Digital2 "brand"?
    Although I returned the Polaroid 720 dual core because the battery time was poor, I did like the hdmi out and the speed that tablet offered.
    Antutu rating 8900. Need to root to get battery rating.
    This 751g works smoothly - 1.2ghz dual core ARM7 chip with Mali 400 gpu, got over 3 hours battery with constant use inc wifi. No hdmi, unfortunately but does have microsd in, headphones and usb connection box says there is a mic input but not there unless in with headphone jack. Also has mic and 2 cameras - .3M on front and 2M on back.
    G sensor very responsive and internet use very smooth. Viewing movies also very good with no skipping. Have yet to try Netflix.
    Made an attempt to root but windows is being very tough to get adb working. Mac OSX got the adb shell right away but I have yet to figure out how to root using adb. Tried to remount and -rw to system folder but have yet to get it to work. I must be doing something wrong. Any help would be appreciated.
    avgary: Wow! You are ahead of even the Internet on this one! I can't find a trace of this tablet anywhere in Google. Is it called the "D2-751G" or the "D2-751"?
    AFAIK Digital2 is just a renaming of the old Diablotek company. I've always been pretty satisfied with their hardware, albeit it's being pretty low-end. I have one of the ancient D2Pad tablets with the 1.2Ghz processor and 1GB of RAM - with a DPI tweak and the Play store hacked onto it, it wasn't bad. That was the first cheaptab I ever messed with
    May have to go to Big Lots and get hands-on with this new unit! Though TBH I don't think it's going to displace the Sero 7 Lite and Sero 7 Pro from my cheap clutches
    Also, I have seen a nice new method of one-step rooting that uses the recently discovered "end-to-end" vulnerabilities in Android - care to give that method a try? I've successfully used it to root two tablets so far...
      Yes, the unit is not "out there" which is why I took a look at it. The problem I have is that there is a driver issue between the mtp and adb drivers. Can't get a windows machine to view it - xp or win7 - in adb. I have tried to rewrite the inf file to change the way the drivers read but they will not work and there is no way to turn off the mtp setting on this tab. It works ok as a media device without turning on usb developer but screws up if you want to get into adb. Maybe I am doing something wrong on the windows side.
      Adb works on the mac side but I have yet to find an exploit that works on the mac to root the tablet. Tried to do it manually but have not been able to change permissions on the tab side.
      All in all, a big PIA.
        D2-751G_MZ from big lots
        Here is the hardware info from the tablet that I purchased, I am still debating keeping it or not as I am unsure if I like the screen.
        What has me stumped is its advertised as 1024x768 and 1.5Mhz speed
        • Model #: D2728GMG but was 751g instead
        GREATWALL DIGITAL2 PLATINUM
        SYSTEM (Android 4.1.1)
        Model: Digital2 Platinum
        Manufacturer: GREATWALL
        Device: d2PAD
        Product: d2PAD
        Brand: Digital2
        Android Version: 4.1.1 (Jelly Bean)
        API Level: 16
        Build ID: JRO03C
        Fingerprint: Digital2/d2PAD/d2PAD:4.1.1/JRO03C/20130617.v014:user/release-keys
        DISPLAY (976x600)
        Refresh Rate: 60 Hz
        Default Orientation: Portrait
        Physical Size: 6.55" (16.65 cm)
        Logical Size: Large
        Density: 160 dpi (Medium)
        Pixels Per Inch: X: 168.89; Y: 177.21
        PROCESSOR (ARMv7)
        Processor: ARMv7 Processor rev 0 (v7l)
        Cores: 2
        Max Frequency: 1200 Mhz
        Instruction Sets: armeabi-v7a, armeabi
        SIMD Instructions: NEON
        MEMORY (915 MB)
        System RAM: 915 MB
        JVM Max Memory: 48 MB
        Internal Storage: 304 MB
        External Storage: 4076 MB
        BACK CAMERA (1.9 megapixel)
        Antibanding: 50hz
        Antibanding Values: 50hz, 60hz
        Auto Convergence:
        Auto Convergence Mode:
        Auto Exposure Lock: False
        Auto Exposure Lock Supported:
        Auto Whitebalance Lock: False
        Auto Whitebalance Lock Supported:
        Brightness: 50
        Camera Name: Camera
        Contrast: 100
        Effect: None
        Effect Values: None, Negative, Sepia
        Exif Make: GREATWALL
        Exif Model: Digital2 Platinum
        Exposure: Auto
        Exposure Compensation: 0
        Exposure Compensation Step: 1
        Exposure Mode Values: Auto
        Focal Length: 4.31
        Focus Distances: 0.95, 1.9, Infinity
        Focus Mode: Fixed
        Focus Mode Values: Fixed
        Gbce: Disable
        Horizontal View Angle: 54.8
        Ipp: Ldc Nsf
        Ipp Values: Ldc Nsf
        Iso: Auto
        Iso Mode Values: Auto
        Jpeg Quality: 90
        Jpeg Thumbnail Height: 120
        Jpeg Thumbnail Quality: 90
        Jpeg Thumbnail Size Values: 160x120, 0x0
        Jpeg Thumbnail Width: 160
        Manual Convergence Values:
        Max Exposure Compensation: 4
        Max Framerate: 15
        Max Num Detected Faces Hw: 0
        Max Num Detected Faces Sw: 0
        Max Num Focus Areas:
        Max Num Metering Areas:
        Max Zoom: 10
        Min Exposure Compensation: 4
        Min Framerate: 10
        Orientation: 90
        Picture Format: Jpeg
        Picture Format Values: Jpeg
        Picture Size: 1600x1200
        Picture Size Values: 1600x1200, 800x600
        Preview Format: Yuv420sp
        Preview Format Values: Yuv420sp, Yuv420p
        Preview Fps Range: 5000, 26623
        Preview Fps Range Values: (5000, 26623)
        Preview Frame Rate: 15
        Preview Frame Rate Values: 10, 15
        Preview Size: 640x480
        Preview Size Values: 352x288, 640x480, 176x144
        Recording Hint:
        S3d Supported:
        S3d2d Preview:
        S3d2d Preview Values:
        Saturation: 100
        Scene Mode: Auto
        Scene Mode Values: Auto
        Sensor Orientation:
        Sensor Orientation Values:
        Sharpness: 100
        Smooth Zoom Supported: False
        Vertical View Angle: 42.5
        Video Frame Format: Yuv420sp
        Video Size: 640x480
        Video Snapshot Supported: False
        Video Stabilization: False
        Video Stabilization Supported: True
        Whitebalance: Auto
        Whitebalance Values: Auto, Daylight, Incandescent, Fluorescent
        Zoom: 0
        Zoom Ratios: 100, 120, 140, 160, 180, 200, 220, 240, 260, 280, 300,
        Zoom Supported: True
        FRONT CAMERA (0.3 megapixel)
        Antibanding: 50hz
        Auto Convergence:
        Brightness: 50
        Camera Name: Camera
        Contrast: 100
        Effect: None
        Exposure: Auto
        Focal Length: 4.31
        Focus Mode: Fixed
        Gbce: Disable
        Ipp: Ldc Nsf
        Ipp Values: Ldc Nsf
        Iso: Auto
        Jpeg Quality: 90
        Max Framerate: 15
        Max Zoom: 10
        Min Framerate: 10
        Orientation: 270
        Picture Size: 640x480
        Picture Size Values: 640x480
        Preview Size Values: 320x240, 352x288, 640x480, 176x144
        Recording Hint:
        S3d Supported:
        S3d2d Preview:
        Saturation: 100
        Scene Mode: Auto
        Sensor Orientation:
        Sharpness: 100
        Video Size: 640x480
        Whitebalance: Auto
        Zoom: 0
        SENSORS (2)
        STK831X ACCELEROMETER
        Vendor: Sensortek
        Range: 58.87 m/s²
        Resolution: 1.0 m/s²
        Power: 0.151 mA
        Delay: 10000 μs
        2AXIS ORIENTATION SENSOR
        Vendor: Amlogic
        Range: 360.0°
        Resolution: 1.0°
        Power: 0.0 mA
        Delay: 10000 μs
        OPENGL 1.X (Mali-400 MP)
        GENERAL
        Renderer: Mali-400 MP
        Version: OpenGL ES-CM 1.1
        Vendor: ARM
        LIMITS
        Texture Size: 4096x4096
        Texture Units: 8
        Viewport Size: 4096x4096
        Modelview Stack Depth: 32
        Projection Stack Depth: 32
        Texture Stack Depth: 32
        Lights: 8
        COMPRESSED TEXTURE FORMATS
        ETC1, Paletted
        EXTENSIONS
        GL_EXT_debug_marker GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_matrix_get GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_point_size_array GL_OES_point_sprite GL_OES_texture_npot GL_OES_query_matrix GL_OES_matrix_palette GL_OES_extended_matrix_palette GL_OES_compressed_ETC1_RGB8_texture GL_OES_EGL_image GL_OES_draw_texture GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_framebuffer_object GL_OES_stencil8 GL_OES_depth24 GL_ARM_rgba8 GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_OES_texture_cube_map GL_EXT_discard_framebuffer GL_EXT_robustness
        OPENGL 2.0 (Mali-400 MP)
        GENERAL
        Version: OpenGL ES 2.0
        Vendor: ARM
        GLSL Version: OpenGL ES GLSL ES 1.00
        LIMITS
        Texture Units: 8
        Vertex Textures: 0
        Combined Textures: 8
        Renderbuffer Size: 4096x4096
        Cubemap Size: 1024x1024
        Vertex Attributes: 16
        Vertex Uniforms: 256
        Varying Vectors: 12
        Fragment Uniforms: 256
        VERTEX NUMERIC PRECISION
        Int: [-2^24, 2^24]
        Float: [-2^127, 2^127], 2^-23
        FRAGMENT NUMERIC PRECISION
        Low Int: [-2^11, 2^11]
        Medium Int: [-2^11, 2^11]
        High Int: Not available
        Low Float: [-2^15, 2^15], 2^-10
        Medium Float: [-2^15, 2^15], 2^-10
        High Float: Not available
        ETC1
        EXTENSIONS
        GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness
        GRAPHIC MODES (RGBA 32bit)
        RGB 16bit (565)
        RGB 16bit (565), Depth 24bit, Stencil 8bit
        RGB 16bit (565), Depth 24bit, Stencil 8bit, Samples x4
        RGB 16bit (565), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
        RGBA 16bit (5551), Depth 24bit, Stencil 8bit
        RGBA 16bit (5551), Depth 24bit, Stencil 8bit, Samples x4
        RGBA 16bit (5551), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
        RGBA 16bit (4444), Depth 24bit, Stencil 8bit
        RGBA 16bit (4444), Depth 24bit, Stencil 8bit, Samples x4
        RGBA 16bit (4444), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
        RGB 32bit (888)
        RGB 32bit (888), Depth 24bit
        RGB 32bit (888), Depth 24bit, Stencil 8bit
        RGBA 32bit (8888)
        RGBA 32bit (8888), Depth 24bit, Stencil 8bit
        RGBA 32bit (8888), Depth 24bit, Stencil 8bit, Samples x4
        RGBA 32bit (8888), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
        FEATURES (21)
        GRAPHICS
        OpenGL 2.0
        ANDROID HARDWARE
        android.hardware.camera
        android.hardware.camera.front
        android.hardware.faketouch
        android.hardware.location
        android.hardware.location.network
        android.hardware.microphone
        android.hardware.screen.landscape
        android.hardware.screen.portrait
        android.hardware.sensor.accelerometer
        android.hardware.touchscreen
        android.hardware.touchscreen.multitouch
        android.hardware.touchscreen.multitouch.distinct
        android.hardware.touchscreen.multitouch.jazzhand
        android.hardware.usb.accessory
        android.hardware.usb.host
        android.hardware.wifi
        ANDROID SOFTWARE
        android.software.live_wallpaper
        android.software.sip
        android.software.sip.voip
        GOOGLE
        com.google.android.feature.GOOGLE_BUILD
        Created with Hardware Info 2.1.7
          I was confused by that too as it was listed for $89.99 in the Big Lots ad today.
          I'd be curious to know if you can get adb to work with a pc because as I said before I had a conflict with the mtp driver and the adb driver. As long as I did not turn on usb developer setting, mtp worked and the tab came up as a Digital2 Platinum portable device.
          You could not turn off mtp setting even though there was a check mark, even after resetting the tab.
          There is NO SUPPORT on the d2info site.
          I am thinking about the lowered price on the Sero 7 Pro, if I can get it. Also wish Polaroid put out their M7 which seems more like a dream than anything else.
            I too got one of these tablets at BL. My idea was to use it for an android project at work so I'd only brick a $89 tablet if i did something awful. It worked for two days (with no development being done on it yet) and now the best I can get it to do is lock up at the "Digital2" logo is I hold the power switch for about 10 seconds. Otherwise it is a brick. Any ideas? I tried combinations of buttons to get a hard reset but nothing works. Paperclip reset just shuts it off.
              Sounds like a bad unit. I, too, tried a variety of things with the "hard" reset in the back but nothing happened except the unit turned off.
              You could try the d2info support. They responded to me the next day on an overnight email.
              Worst case, just swap it out. Better now than 30 days from now.
                Very likely it's bad. Digital2 replied to me with instructions for a hard reset. The logo was supposed to appear and then a menu. The logo appeared but no menu. I sent that information to them and no repose after that.
                What I can say happened is that I am sure the battery went dead overnight on Friday. It seems that if the battery drains out on this tablet it will never start up successfully again. It died overnight on Thursday and I had a heck of a time to start it on Friday, but thought it was a one time thing. It claims to be charging with their wall wart or USB but nothing more.
                Don't let the battery die or you will have a brick.
                  Digital2 Tablet from Big Lots. Not good
                  Since last Saturday I have had 3 of these. First one gave me trouble on 3rd day. It shut itself off, and took at least 10 seconds to get it to come back on. Within another 2 days, I could not get it to come back on at all. Had static logo with no boot to menu screen. Attempted to reset to no avail. Exchanged #1 at Big Lots yesterday. Brought #2 home, attempted to load micro SD card. Spring mechanism kept shooting it out across the room. Went right back to Big Lots for try #3. Brought it home, used it last night, shut it down, took a long time pressing in starter to get it to come back on this am. Was downloading some books, got a warning that it was at 14% power. Turned off app, as I did, static sound, went to black, have not been able to get it to come back on. Black screen even after attempt to charge and reset. Thing is garbage! Don't waste your time or money. I am going to return it today, get my $ back, and wait until Christmas to get Samsung Galaxy.
                    Finally got to see one
                    I finally got to lay eyes on one at a Big Lots, and you're right, it doesn't look like a "1024x768" format tablet to me - it looks more like a conventional (albeit maybe higher resolution) 7" tablet.
                    Hey, look! The Digital2 site finally caught up with Big Lots: http://www.d2pad.info/index.php?opti...age&Itemid=425 - stuff there claims it's a 1024x600 display.
                    Doesn't look like there's a firmware available for it anywhere on the site though
                      Firmware! (And update for lock-up issue?)
                      Hey, check this out!
                      Looks like they made a recovery firmware available as part of an update! (Which may address the "locks up at the Digital2 logo" issue that you were reporting...)
                      Now if only I could get hold of similar for the Polaroid PMID720
                        YES... blasted Polatoid
                        I can't believe they refuse to post a recovery for the PMID720.
                          Hello!
                          Don't hold your breath. For these guys, that's pretty much par for the course.
                          The PMID706 has been out for months, and still no recovery image for IT, EITHER. A model is usually discontinued by the time (or before) a recovery image is released...
                          73 DE N4RPS
                          Rob
                            D2 Platinum
                            <p>
                            Hey, check this out! http://www.d2pad.info/index.php?opti...amp;Itemid=423 Looks like they made a recovery firmware available as part of an update! (Which may address the &quot;locks up at the Digital2 logo&quot; issue that you were reporting...) Now if only I could get hold of similar for the Polaroid PMID720
                            Yeah I saw that on their website too. They seem to do more support for their tablets than Polaroid, but we shall see. I saw this one at Big Lots and told a buddy of mine that wanted one. He got it and had me load stuff to it for him, games and other apps. Seems pretty nice and does hold a charge better. I like the screen myself. Box says it&#39;s HD 1024 x 600 but I see thats not the case from the posts. I may drop my Polaroids and buy one. Anybody know who owns and where Digital2 is located? Looks to be CA since its hours are Pacific Time but that doesn&#39;t mean much.</p>
                            <p>
                            &nbsp;</p>
                            <p>
                            Anybody know if there is a chance of seeing the M series Polaroids anytime soon? Polaroid originally said summer but I bet they may wait until its closer to the holidays.</p>
                            "It's full of stars!"
                              Support is great but....
                              I'm on my third 751G and it just bricked last night! D2 has replaced the original tablet twice - quickly and without question (including a free PC videogame each time - I'm not a gamer so I don't know anything about them) but I think I'm done. I think I'll be returning both tablets on the prepaid UPS label they sent me and asking for a full refund. They did pre-ship tablet #3 in advance of my returning it. I haven't thrown #2 in the mail yet so I considering returning both of them.
                              The third 751 definitely had updated firmware but I am now at the dreaded "logo lockup" once again. It seems that if the firmware decides the battery is "dead," whether it actually is or not, it puts the tablet into some kind of a lockup mode and it will never boot again. There is no hard reset. After about 30 seconds of holding the power button (and no matter what combination of volume buttons, time, what have you) you will get the Digital2 logo and that's where it stays forever. I left tablets 2 and 3, both fully charged, in the logo lockup state this morning before leaving for work in the hopes that the batteries would be fully drained and that might cause some sort of hard reset, but I am not hoprful.
                              It's a shame, it's not a bad tablet when it works. But you get about a week and then it locks up. So to me it's a 39 cent chicken. Spend a few more bucks and get one that works.
