Need WIFI and Bluetooth files for sunvell t95z plus 2/16
    Hello,
    I upgrade my firmware to android 7.1.1, everything works fine except I lost wifi and bluetooth.
    I understand I probably need to flash some other files to make them work. can you provide them to me please?
    ( i took firmware from this post : http://freaktab.com/forum/tv-player-...ta-core/page18 )
    thanks!!
    since I have upgrader my box to this firmware, everything works great except one thing.
    The ethernet connection stops working when the box has been in sleep the whole night (couple hours)
    I then need to unplug the cable and plug it back in and then all is good... anybody can help me fix that? is there a setting somewhere I am missing or is it a bug in the firmware?
    thanks!!
    firmware is:
      I finally got the right firmware with wifi and bt that works so disregard this
      thanks
        thanks
        Hi ringorinfret ,
        first please stay with your Questios over your Box as possible in one Thread ,
        it is not needed to make for ever Q. a new Topic , okay !!!
        I merged them in this Topic .
        Does your Box now run as expected ??? I hope it , good luck , report any Bug
        of your Box here , have a nice Day / gefattern
          hi, sorry about that, that was 2 seperate issues, one with wifi/bt (i had the wrong image)
          the issue I am still having is with ETHERNET not working when the box comes from sleep (using power button on remote to power down/up the box) if it had been "sleeping" for a long time
            Hi again ,
            this Ethernet Bug sounds like a Software Bug , but strange that this happens on
            both FWs , is that right or not ??? why not only use Power Off/On , or Daydream ???
            good luck / gefattern
              I finally found what the problem was... Bought new router a couple of weeks ago and the DHCP was releasing the address.... Grrrr i am glad i found it!
                Hi ,
                nice to hear that you solved your Problem .
