The firmware that flashed on it I think is for a Nexus Box as The Nexus logo pops up when box is started and then the screen says no connection I have used mini sd card to try and install new update with no luck any info would be greatly appreciated
wrong firmware flashed
I mistakenly flashed wrong firmware on my a95x nexbox , usually it would be no problem to fix as I would just flash the right firmware on it but when I now try to flash it the usb burning tool will not connect to the box no matter what I do its like its not there .
The firmware that flashed on it I think is for a Nexus Box as The Nexus logo pops up when box is started and then the screen says no connection I have used mini sd card to try and install new update with no luck any info would be greatly appreciatedTags: None
There are currently 2052 users online. 3 members and 2049 guests.
