MK908 and PS3 controller
    Hello,
    I`m writing from Argentina, and bought a month ago a MK908 device. I recived it a week ago, is a good device (some problems with wifi, and videos) but I have a question about it.
    Can I use MK908 with PS3 controller (wireless)? I watched some videos in youtube with sixaxis, but when I tried to paired it, I can`t do that.
    the device is compatible?
    As I make it work?
    I want to play games like Shadowgun
    Thanks a lot for your help
    Originally posted by sistemika View Post
    Hello,
    As I make it work?
    Honestly the best luck I have with ps3 controllers is direct USB connection. It fully supports that I know, not sure how well sixaxis works with current rk3188 firmware.
    If my work benefits you and you want to help out the cause, feel free to
    http://www.hoaby.com/android/donate.gif
      i was useing ps3 controler with sixaxis app and it was working without a problem on mk808b.
      try using sixaxis pc tool to put your stick bt adres into gamepad.
      it need to share the same address
      Everything is possible if we work together!
      ApkFreak
        Sorry cant help with mk908 but t428 works fine. Like Lewy says u need to use the pairing tool and USB cable at least to change the bluetooth/Mac? address. Also check your input settings. Also make sure your ps3 controller is genuine
          Thanks a lot for your comment. Do you have a tutorial to connect a wired PS3 controller? Do you use a original PS3 usb controller or original one?
          It`s works with only plugged in USB port? What port do you use? USB or OTG?
          Many thanks.-
            I tried by all means to connect the PS3 joystick (bluetooth) but I could not.
            I also tried to control the Xbox 360 with the PC connector, but the procedure is difficult and so far I could not.
            I want to see then, that use and control as their devices are configured with MK908.
            I would also like to know if any of you have tried to connect a USB hub and if it has worked. I tried but does not work (but many is very old). If any of you work, I would like to know the brand of the device.
            Thank you very much for your comments.
              I have xbox 360 controller by razer (wired USB) and that does not work on MK908 V3. I tried various tutorials on the net but in vain.
              ROM - Tronsmart MK908 V3 Finless 1.4a ~Legitsu
              KERNEL - ddr720_CPU1600h_gpu600_MK908V3
                It does work but for some reason you cant have two input devices attached via usb. plug only the ps3 controller in and use droidmote or something similar to navigate sixaxis app and it should pair fine
                  Yip i have a razor onza controller that doesn't work on any of my android devices but official wired or wireless 360 ones work on all of them
