Sent from my Pixel XL using Tapatalk
Flashed wrong firmware
So I have an abox A1 Plus and I have been running a95x 2 G / 8 G firmware since I got the box. I have always had a problem getting the box to connect to the USB burn tool and the two or three times I have got it to connect I seem to forget how I do it. So I flashed m8s pro+ firmware on accident now I'm trying to get it back to a95x firmware but I'm struggling to get it to connect to the burn tool. I also have a hard time flashing via SD card or USB flash drive, because my box does not have a reset button in the av hole. it has a reboot button that is on the bottom that you cannot hold it's basically just shut the power off and then back on. Can someone point me in the right directions so that way I can class the right firmware.
Tags: None
The hold in the bottom will be the reset button.
You may need something as small as a pin to hold it in and it may be fiddly but this is the one that you will need to use to get recognition from either the Burn tool or SD card flashing methods.
There are currently 4057 users online. 0 members and 4057 guests.
