Switch on and performance looking Good,
Easy startup, Google etc.
WiFi and Ethernet Good
Added some thickness to previous Heat Sink Model used
Much the same Better heat sink and the Bonus extra USB ports to the Dremel we must go.
Closer Top Side, DDR3 ram
Closer Under Side
UI stock
Info-64GB
Root
A1SD
Can Compare this to 3/32gb unit
http://freaktab.com/forum/tv-player-...481#post610481
Much the same, remote etc all the same...
Just a quick look at the 3/64GB.
I guess you need to think the extra $ per GB Sd card or Box, I am not a fan of these new smaller TF cards so this will do me fine.
Gearbest
