based on MorkaMod v.1.14 (including the last fix)
Attention! At ARNOVA 8G2 4Gb or resistve touch is not works!
Differences firmware.
- Support for Ad-hoc
- You can choose the size of userdata - 0.5, 1, 2, 3 and 4 Gb
- Sections (system, cashe, userdata) converted into a format the ext4 file system
which is much faster read/write data,
allows to edit, add and delete files in it.
- Set aside for user data 0.5-4Gb memory. This will allow
install more applications.
With the increasing number of applications increases the start time.
- Updated some applications.
Thanks fenice57 and Morka
- Added support for modules BT, 3g USB-modem, GPS *
- Interface HoneyComb (Android 3.0)
* Requires verification and debugging.
Manual and drivers in the archive
ROM -> AN8G2 v.5.4 by Sowa (137 Mb)
