2/16 GB Ram,
Using the Amlogic 905w CPU
Classed as a low budget CPU to compete with low budget Rockchip. whatever that means
Limited clocked to 1200, 4k-30 fps Max
Running 720p upscaled, I guess you would call it (adds more speed) or less CPU usage
A Budget Box.
Netflix not compatible to be installed by Google play
YT playback 720p
Installed Kodi 17.3, plus addons, often fails to exit Kodi. Hangs
With 2.4Ghz and 10/100 Net speeds and that with limited performance don't expect BIG things
For what it is and the market it is aimed it could do its Job.
let's have a look around the Unit and some tests Later.
The Box
What's in the Box
Ports, front has a good looking clock display
Under side , no vents
Top Side, use of Weight block as heat good idea, runs cool I find
Unit
Main Top View
Thanks Gearbest for the opportunity to Show and tell.
Further discussion can be found > http://freaktab.com/forum/tv-player-...-android-7-1-1
