are they ok to buy?
What is mesuvida
Originally posted by pauljbl View Post
What box would you recommend with good custom ROM support?
if you want a S912 Box , i would take one of the Boxes that are supported by Superceleron ,
like H96Pro+ , looks like many Users bought that Box , but you have to choose what Box
you want to buy , important look for your needs , if you want to use Netflix and others u need
a Box with Widevine (DRM) Support . Hope it helps / gefattern
There are currently 1620 users online. 0 members and 1620 guests.
