Great news for Yoka KB2 Pro Owners
    Today Androidtvbox site post a new firmware for this box. They said is Android 7.1. My box is on the way. Can anyone confirm that?
    Thankxxx
    Firmware was dated 2017-07-28.
      Thankxxx
      __________________________________________
      YOKA KB2 Pro 3GB 32GB Android 7.1.1 (20170728) Firmware
      only 3GB 32GB Pro Version DDR4 RAM
      We have good news, there is a new firmware (with Android 7.1) for YOKA KB2 Pro TV Box (update 20170728). This is a big plus for the Videostrong
      Update with free Rashr App from the Play Store:
      Rashr App Click >>> restore from memory, download .img file and follow the instructions.
      It works out!!!
      Important for emergencies: First create a TWRP fuse and mark all the hooks in the fuse.
      Create a boot SD card with Amlogic_SDcardMaker_BootcardMaker_burnBootCard_v1. 0.1
      You need the following files:
      1: BootcardMaker.exe
      2: langu.ini
      3: u-boot.bin
      You need TWRP.img S912 for Android 7.1
      Rename TWRP.img to recovery.img
      Important: Not all SD cards work, no bigger than 16GB, I have an 8GB Sandisk
      SD card uses:
      1: starts the boot card manufacturer
      2: Selects the SD card at the top.
      3: Hook on Partition Yes
      4: Open File u-boot.bin below
      5: Click Make
      Fat Fat 32 done
      Finally, just copy the TWRP file with the new name recovery directly to the SD card.
      SD card boat:
      Turn off the Yoka KB2 Pro completely, insert the SD card and press and hold the front button. Turn on the box and when the Yoka logo arrives, wait 5 seconds, slowly count to 5 and then go.
      Good luck.
          Hi ,
          please use English not German , okay , so if possible change the flashingguide
          to English .
          greetings / gefattern
            Did you saw any improvement? In terms of UI or boot time (OS and programs), i notice some minor times.. but in 3D performance (yes i confess, I also like to play some games, kinda asphalt, real racing, etc)... it becomes worse!!!
            Tronsmart MK908II RK3188(non-T)
              Did anyone retain a copy of the firmware? All links for this version are dead now
