My board is MX4 v01
Debian on rk3229 is it possible?
the 3229 boards are totally different each from other even if the disposition of components are exactly the SAME
I have a mx4n and it boots, and on mx4vr it DOESN'T . The mx4n uses NAND , the mx4vr uses EMMC and i discovered it by accident analyzing the uart console, such as I have a 3229 2 giga/8giga that doesn't boot at all.
that is the reason why an universal method hasn't yet released to community,
Actually the method involves access by UART, program the GPT instead of RKPARAM and write the right things into right place.
willerson is doing great efforts to make it work, my biggest thank to him, and actually it is booting either on nand , either on emmc but ONLY ONE core is up and the process is stuck there.
He is actively searching why othe 3 cores don't work
KERNEL is 4.4
regards, Fabio
Great work guys! Please contine working and offer some more information for "Testers". I am still playing with my V88 mini which has 1GB/8GB Hardware. I don't know yet which board it has internally. But I wanted to try the SD-Card-Version. Would love if you keep going the development! Maybe also respeaker-guys are interested in the development and you can offer colaboration.
Edit: Ok guys, I got it a try on my V88 Mini 4k 1GB/8GB. - What shall I say, I am blasted! It worked installing the respeaker-image from scott (thanks to mxqproject) https://mega.nz/#!HvJygI4K!Z7KETGEQG...Tjb18foN4yY1dw
I also got the freezings sometimes after 5 minutes, sometimes less. - I replaced the power supply with a diffrent one. No it worked maybe for 10 minutes. I tried serveral ones and atm i found a working one from my old G-Box 2.1 from 2012. I made the apt update && apt upgrade as root and also got it working from remote via user. You are not allowed to login via root from remote since a while. So you need to use a user... anyway I think that's nothing new.
I will also try a real stable power supply if it stays working. - At the moment I am amazed what is going on which that trash device. IMPORTANT: I also noticed a big performance incresing with the more powerful power supply! It feels like a speedy raspi at the moment and I think this should be the case if you compare the hardware.
What's annoying, the device seems to switch the MAC-Address on every boot, so it gets always a diffrent IP from DHCP. So maybe there will be a fix or it works when you install it on internal storage in the future. - Also firefox is not opening anymore after upgrade-procedure, before it worked. At least the device seems more stable after serveral tries to update it stays on. I always fixed the issues and started upgrade again.
UPDATE: I guess the free RAM is to low. I saw free RAM of 223 MB on my device and guess firefox will need in a version above 60 more than this size of RAM... Maybe there will someone find a workaround or how to free RAM. - But honstely, yes 1 GB is not really much I know.
I hope you guys keep on developing and of course I will test anything that helps!
Cheers and happy developingLast edited by suppenkasper; 12 September 2019, 18:08.
suppenkasper
ty for your contribution , and about your question i can answer some infos, if you already did well will be useful infos for others
you are not allowed to login via root from remote since a while. So you need to use a user
and about the fixed ip you have to stop network manager and fix ip in /etc/network/interfaces
(ty willerson for this)
please can you install htop and say me how many cores your boards shows ???
@bjddragon
I know that issue, all I can say to test more respeaker version, may be also the old ones and MAYBE you'll finde one working, and I repeat MAYBE
Those boards are litterally different one from other not only in words but in facts.
Still needed people able and willing to code , must investigate better the boot process, the trust zone since from there are many problems.
and testers should have at least the ability to connect uart to boards and report the logs , and testers are MOSTLY welcome
cheers
Please can every body post the exact firmware their boards have , or even better , upload on mega or somewhere ?
One of the FIRST and BIGGER obstacle( may be ) coud be the loader ( miniloader, miniloaderall, miniloader ddr 2 and so on , those names you could find in the dump of your firmware or logging by uart)
cheers
I use the latest unofficial ATV-Version before developing unfortunately stopped on my V88 Mini.
https://forum.freaktab.com/forum/tv-...005#post702005
Unfortunately the device stopped working after 4h operation time. I installed also other stuff, but only Vlc opened. Kodi and Firefox don't start.
Htop is already installed and I see all 4 cores operating. Also when I start installing something all 4 cores work.
So I think most problems are:
Changing MAC address, but I remember there was a workaround already for Android. It has something to do if you install an image from another box the MAC information doesn't fit anymore and somehow the board creates new virtual ones. There was somewhere a fix, but can't find the information right now.
I mean I can open the Box, but can't remember if there were some Pins to get UART to work if it helps...
I can't solder at the Rk3229. I have only an usual soldering Stick.
The power supply needs to be changed to a proper one or we need to find possibilities to lower power consumption.
WiFi is not working
Sound only via 3.5mm no HDMI sound
Device crashes after a while of operation time
Edit:
Kodi crashlog:
Code:############## Kodi CRASH LOG ############### ################ SYSTEM INFO ################ Date: Fri Sep 13 12:04:11 CEST 2019 Kodi Options: Arch: armv7l Kernel: Linux 4.4.138-respeaker-r0 #2 SMP Wed Jul 25 11:29:18 CST 2018 Release: Debian GNU/Linux 9 (stretch) ############## END SYSTEM INFO ############## ############### STACK TRACE ################# gdb not installed, can't get stack trace. ############# END STACK TRACE ############### ################# LOG FILE ################## 12:04:10.444 T:2937293792 NOTICE: special://profile/ is mapped to: special://masterprofile/ 12:04:10.444 T:2937293792 NOTICE: ----------------------------------------------------------------------- 12:04:10.445 T:2937293792 NOTICE: Starting Kodi from Debian (17.1 Debian package version: 2:17.1+dfsg1-3). Platform: Linux ARM (Thumb) 32-bit 12:04:10.445 T:2937293792 NOTICE: Using Release Kodi from Debian x32 build 12:04:10.445 T:2937293792 NOTICE: Kodi from Debian compiled from 2:17.1+dfsg1-3 by GCC 6.3.0 for Linux ARM (Thumb) 32-bit version 4.9.25 (264473) 12:04:10.445 T:2937293792 NOTICE: Running on Debian GNU/Linux 9 (stretch), kernel: Linux ARM 32-bit version 4.4.138-respeaker-r0 12:04:10.448 T:2937293792 NOTICE: FFmpeg version/source: 3.2.14-1~deb9u1 12:04:10.449 T:2937293792 NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available 12:04:10.449 T:2937293792 NOTICE: ARM Features: Neon disabled 12:04:10.449 T:2937293792 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi 12:04:10.449 T:2937293792 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi 12:04:10.449 T:2937293792 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons 12:04:10.449 T:2937293792 NOTICE: special://masterprofile/ is mapped to: /home/respeaker/.kodi/userdata 12:04:10.449 T:2937293792 NOTICE: special://envhome/ is mapped to: /home/respeaker 12:04:10.449 T:2937293792 NOTICE: special://home/ is mapped to: /home/respeaker/.kodi 12:04:10.449 T:2937293792 NOTICE: special://temp/ is mapped to: /home/respeaker/.kodi/temp 12:04:10.449 T:2937293792 NOTICE: special://logpath/ is mapped to: /home/respeaker/.kodi/temp 12:04:10.449 T:2937293792 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin 12:04:10.450 T:2937293792 NOTICE: Local hostname: v2 12:04:10.450 T:2937293792 NOTICE: Log File is located: /home/respeaker/.kodi/temp//kodi.log 12:04:10.450 T:2937293792 NOTICE: ----------------------------------------------------------------------- 12:04:10.573 T:2937293792 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files 12:04:10.661 T:2937293792 NOTICE: load settings... 12:04:10.766 T:2937293792 NOTICE: Found 1 Lists of Devices 12:04:10.766 T:2937293792 NOTICE: Enumerated PULSE devices: 12:04:10.766 T:2937293792 NOTICE: Device 1 12:04:10.767 T:2937293792 NOTICE: m_deviceName : Default 12:04:10.767 T:2937293792 NOTICE: m_displayName : Default 12:04:10.767 T:2937293792 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO) 12:04:10.767 T:2937293792 NOTICE: m_deviceType : AE_DEVTYPE_PCM 12:04:10.767 T:2937293792 NOTICE: m_channels : FL,FR 12:04:10.767 T:2937293792 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000 12:04:10.767 T:2937293792 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT 12:04:10.767 T:2937293792 NOTICE: m_streamTypes : No passthrough capabilities 12:04:10.767 T:2937293792 NOTICE: Device 2 12:04:10.768 T:2937293792 NOTICE: m_deviceName : auto_null 12:04:10.768 T:2937293792 NOTICE: m_displayName : Dummy Output 12:04:10.768 T:2937293792 NOTICE: m_displayNameExtra: Dummy Output (PULSEAUDIO) 12:04:10.768 T:2937293792 NOTICE: m_deviceType : AE_DEVTYPE_PCM 12:04:10.768 T:2937293792 NOTICE: m_channels : FL,FR 12:04:10.768 T:2937293792 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000 12:04:10.768 T:2937293792 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT 12:04:10.768 T:2937293792 NOTICE: m_streamTypes : No passthrough capabilities 12:04:10.791 T:2937293792 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml) 12:04:10.792 T:2937293792 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml) 12:04:10.792 T:2937293792 NOTICE: Default Video Player: VideoPlayer 12:04:10.792 T:2937293792 NOTICE: Default Audio Player: paplayer 12:04:10.792 T:2937293792 NOTICE: Disabled debug logging due to GUI setting. Level 0. 12:04:10.792 T:2937293792 NOTICE: Log level changed to "LOG_LEVEL_NORMAL" 12:04:10.793 T:2937293792 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml. 12:04:10.798 T:2937293792 NOTICE: Loaded playercorefactory configuration 12:04:10.799 T:2937293792 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml. 12:04:10.799 T:2937293792 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping. 12:04:10.843 T:2937293792 NOTICE: Running database version Addons27 12:04:11.221 T:2937293792 NOTICE: ADDONS: Using repository repository.xbmc.org 12:04:11.327 T:2917134752 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 300 ms 12:04:11.701 T:2937293792 NOTICE: Checking resolution 16 12:04:11.702 T:2937293792 NOTICE: CWinSystemX11GLESContext::CreateNewWindow 12:04:11.707 T:2937293792 NOTICE: CWinSystemX11GLESContext::GetVisual() m_pGLContext:(nil) GetVisual 12:04:11.707 T:2937293792 NOTICE: Create new CGLContextEGL at CWinSystemX11GLESContext::CreateNewWindow, m_dpy=0x80ada7f0 12:04:11.714 T:2937293792 ERROR: failed to initialize egl display 12:04:11.714 T:2937293792 ERROR: Failed to find matching visual ############### END LOG FILE ################ ############ END Kodi CRASH LOG #############
Code:speaker@v2:~$ firefox MESA-LOADER: failed to retrieve device information libGL error: unable to load driver: rockchip_dri.so libGL error: driver pointer missing libGL error: failed to load driver: rockchip ExceptionHandler::GenerateDump cloned child 9351 ExceptionHandler::WaitForContinueSignal waiting for continue signal... ExceptionHandler::SendContinueSignalToChild sent continue signal to child Firefox crash info: BuildID: 20190904002323 CrashTime: 1568369539 FramePoisonBase: 0000004041121792 FramePoisonSize: 4096 InstallTime: 1568304331 Notes: Debian GNU/Linux 9.11 (stretch) ProductID: {ec8030f7-c20a-464f-9b0e-13a3a9e97384} ProductName: Firefox ReleaseChannel: esr SafeMode: 1 SecondsSinceLastCrash: 42839 StartupCrash: 1 StartupTime: 1568369537 ThreadIdNameMapping: 9332:"Gecko_IOThread",9333:"Timer",9334:"Link Monitor",9335:"Socket Thread",9336:"JS Watchdog",9345:"BGReadURLs",9346:"Hang Monitor", Throttleable: 1 UptimeTS: 1.908094562 Vendor: Mozilla Version: 60.9.0 This report also contains technical information about the state of the application when it crashed.message:
https://www.bilder-upload.eu/bild-2a...74149.jpg.html
https://www.bilder-upload.eu/bild-16...74186.jpg.htmlLast edited by suppenkasper; 01 October 2019, 23:19.
Originally posted by fabiobassa View PostPlease can every body post the exact firmware their boards have , or even better , upload on mega or somewhere ?
cheers
TY both for quick replay, but I was mispelling my thought;
what i need is the exact name of the original ANDROID firmware:
It will be something such as
rk3229_6.0_box_MX4VR_SSV6051p_SpecTek_flash_tongw_ V88_RKMC-update_20171208.img
rk3229_6.0_box_MX4N_SSV6051p_SpecTek_flash-update_20170405.img
mxqpro-6051-nv2-1114.img
rk3229_7.1_box_MX4VB_SSV6051p_SpecTek_flash-update_20171209.img .....
and many others.
well is needed that name
EDIT
ty scottmu64 for his KingboxRK-8703-7.1nv3-kodi-1225.imgLast edited by fabiobassa; 13 September 2019, 16:03.
ty suppenkasper for your firmware
Well the reason on some boards it runs and on some other only red led " COULD " be the loader and the way it calls the trust img
I can confirm that not all loader are egual and it depends on which " type" of ddr is on board . E.G I installed the same firmware of suppenkasper and for me was NOT working the sd until I changed the loader.img and u-boot.itb compiled from
It is really a hard work, many many variables on those economic boards and also, I suppose , lack of informations because they can be a cheap alternative to raspberry and so on.
Anyway for ALL those are willing have linux for better performances on videos, I REPEAT : stay on android and, e.g. look for
LeelboxRK-8703-7.1nv3-kodi-1225.img
for fan of linux , well more work to do !!!
So thanks to big big work of willerson and night and night of testing there is a " good " hope of an universal linux on those economic rk3229 boxes
now experiencing a strange situation :
1) original kernel + original dtb from an old respeaker images >>>>>> 4 CORES but no lan neither internal nand neither video because was headless
2) new compiled kernel + new compiled dtb >>>>>>>>>> ONLY 1 CORE , but lan and rknand and video are working
We have original .config from kernels and the two dtbs .
Does it exist a way to merge the functionality of the two kernels / dtbs to obtain a full workin board or there is some incompatibility among pcsi, lan rknand ? ?
Hi guys,
if you are interested in my dmesg: https://pastebin.com/7uUDhwM4
I am running already a TVHeadend Server on the Rockchip 3229 V88 Mini 4k Device. I used the tutorials for raspberry pi's because it seems like it's running raspian 9 stretch and since I upgraded the os within the last week it's a very stable headless server. But unfortunately I can't get my Terratec Cinergy S2 USB HD card running. It needs a driver which I put to /lib/firmware and also found a new ds3000.ko file which I put into /lib/modules/4.4.138-respeaker-r0/kernel/drivers/media/dvb-frontends/ but unfortunately it doesn't get loaded proper.
Has anyone some good hint or ideas even when this is not a tvheadend forum? - The problem is noone has this device running with tvheadend yet, so if I ask there they will ask we just support raspi or something...
here is my output of lsusb
Code:root@v2 /home/user > lsusb Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 002: ID 0ccd:00b0 TerraTec Electronic GmbH Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Code:root@v2 /home/alex > dmesg | grep DVB root@v2 /home/alex >
There are currently 2001 users online. 1 members and 2000 guests.
