Mecool M8S PRO W TV Box - Amlogic S905W + A7.1.2 2/16gb + (L1) 4K VP9 H.265
I brought a m8s pro w box, thanks to gearbest for international shipping.
Intended to use that woth hp v192 LED monitor with resolution 1366*768@60hz with VGA input only. Tried to use it with a converter (HDMI to VGA with audio out). It didn't work. Monitor says input out of range. Please select 1366*768. Don't have any other display at hand. Stuck here. Help is very much appreciated guys. What can be done? Is it possible to change the output resolution? If yes, can anyone please give how to make the change blindly with the remote ( like down key twice, right key 4 times.. sequence like that maybe?) . Please help..
A newer version of the MeCool M8S Pro W with full Android TV is now available. Supports Netflix in 4K @ 30fps, remote is voice activated, Widevine L1 approved DRM.
The Android TV is like the Shield, Mi box type interface, I.E. 10 foot lean back. Available for 41.99 from large China retail outlet "B" Just make sure it is the latest, as many Pro W's on market.
This unit has Nougat 7.1.1 and full Android TV interface from manufacture.
i think only u can help me out..because no one on the internet is talking about this box i have a problem.. During intitial setup
On the setup
Ipaired my remote
And then connected to my wifi
I then chose the option to put my email and password for the account..it signed in but in the end it was asking for location access i gave it but then i receive an error saying google sign in has stopped
And now i am stuck ..even whei restart box always stuck at the same loop
i dont know what to do...i havent even seen its home screen ..i am in the loop of setting up device
I think maybe faftfac resetting it may solve it...but i dont know how to do it ..as i dont know how to open recovery mode
Hi guys, I bought one of these boxes on gearbest, and it works like charm for about 2-3 hours then starts to freez picture and restarts.
I ask them to send me firmware but I can't update it because box uses newer firmware then the one they send. Anyways the link to the firmware is here if anybody needs it (it's not an .img upgrade but the local update for going true UPDATE app:
I found here on forum .img file tryed to downgrade with SD card burn maker, but the box will not go to recovery. What would be the easiest way to come to recovery, and which is recomended firmware that works OK?
THX
Has anyone succeeded in booting to CoreELEC ?
My MECOOL M8S Pro W won?t boot to CoreElec. It goes straight to TWRP. I am using a USB Drive, not an SD card. I have tried both USB ports.
I used the correct DTB file (gxl_p281_2g.dtb) as dtb.img.
Any help please ??
I forgot to mention that I have Nexus ATV installed, from Freaktab.
[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
WARNING: Newer M8S PRO W units may have hardware revisions that make them incompatible with earlier firmware releases. My advice would be to only flash a custom ROM that's based on a known-good OEM firmware release for your box. That said, this latest release is also compatible with the new M8S PRO PLUS units configured with
There are currently 910 users online. 0 members and 910 guests.
