[ROM] Magicsee IRON+ - SCV1-ATV - Android 7.1.2 ( ANDROID-TV VERSION )
    Here is the ATV 7.1.2 version
    Many thks to gearbest for sending me the device to play
    Thks trebor for the beta test!
    READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
    Changelog V1:
    • 45% based on stock +/-
    • Twrp
    • unrooted ( Yes now you can install magisk or whatever you use to root, use the included update app to flash it! )
    • Big optimization, is really fast now and i mean fast... you will see it!
    • Navigation should be smooth as silk and fast.
    • New Boot Logo, many thks to danielelek90 for the great work
    • Netflix, youtube, playstore...etc... fully working
    • 4k Youtube support.
    • Fixed white settings crash on Android TV
    • initd.d support.
    • Enabled Multiuser (Max 3 users)
    • Enabled Status and Navigation bars ( not a Android tv default, since android tv dont have both! )
    • Added Status and Navigation's bar's auto hide!
    • Fixed UI crashes
    • Some UI changes:
    • - organized the icons on status bar dropdown.
    • - fixed and screenshot function on navigation bar
    • - removed led control from navigation bar
    • - Fixed and added back power button in navigation bar
    • PS3/PS4 gamepad support ( only with cable... )
    • Added Xbox360/XboxOne gamepad support ( cable, wireless and Bluetooth )
    • Added Dragonrise USB HID game controllers.
    • Removed Navigation and Status bar just like Real ATV's. ( so dont ask for it )
    • Wifi connection speed should be a little better.
    • Permissions fixed. ( lots... )
    • Many KL's added.
    • Fixed AMCODEC playback.
    • Some audio mods.
    • FTMC Build 31
    • Some video optimizations ( tested in two different's online ISP's TV and both give HD streams just fine )
    • Optimized some animation stuff!
    • And a lot of other stuff that i dont remember now! ( ye ye i know i need to make notes... )
    • And of course all the other ATV mambo jambo LOL ....
    Bugs V1:
    • on setupwizard dont choose tablet to login, choose normal login since the table/etc.. is not working.
    • In youtube app when you search if it ask to access you microphone deny it or else it will crash.
    • Possible a lot more!
    Want to buy me a beer?
    Download SCV1 IMG:
    Install instructions:
    • Use usb burning tool....
    Where to buy:
    1º BOOT MAY TAKE +/- 6 MINUTES!
    THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
    USE AT YOUR OWN RISK!
    Enjoy it!
    Will this work on the c400
    thanks
      May I ask wether fw suits to x92 2gb/16gb s912 box?
        link is gone is it lost forever ? i had this installed for years with much pleasure.
        My problem is : after years of use, now it black screen here and there
        during boot, sometimes it boots but turns off by itself after some youtube or other app when changing app.
        I suspect the power supply, I guess the rom has nothing to do with it.
          No its not gone forever, i will upload it again as soon as i can.
            Updated 1º post with a new link, both ATV and non ATV builds are inside.
