How to improve wifi for MXQ PRO+ ?
    I got a unit of MXQ PRO+, which based on the spec, it is a S905X based with 2 GB/16GB.
    The problem I have since day 1 gotten the unit is that, it has poor wifi reception.
    I have open up the box to look at the inside, with the hope of shifting the wifi antenna. But to my disappointment, there is not even a visible internal wifi antenna cable.
    I have attached the photo here.
    Somebody was saying the bottom PCB pattern is some kind of antenna, but it could be the Bluetooth antenna ?
