New product!$100 coupon code:[NAPWDBJL] for VORKE V6 Barebone Game PC Intel Core i7-6700HQ 3.5GHz Nvidia GTX960M 4GB VRAM ac WIFI Gigabit LAN
    VORKE V6 Barebone Game PC Intel Core i7-6700HQ 3.5GHz Nvidia GTX960M 4GB VRAM ac WIFI Gigabit LAN SATA 3.0 Type C HDMI+DP SATA USB3.0
    VORKE V6 MINI PC is powered by the Intel Core i7-6700HQ, a quad-core processor based on the Skylake architecture. In addition to four CPU cores with Hyper-Threading clocked at 2.6 - 3.5 GHz, the chip also integrates an HD Graphics 530 GPU and a dual-channel DDR4-2133/DDR3L-1600 memory controller.
    Nvidia GTX960M
    An upper mid-range, DirectX 11-compatible graphics card, GeForce GTX 960M is based on Nvidia's Maxwell architecture and manufactured in 28 nm. The GTX 960M offers 640 shader units clocked at 1097 - 1202 MHz (Boost) , besides the fact that it comes with a 4GB Video RAM.
    Dual Channel DDR4, Maximum 32GB, Dual M.2 22*80 SSD
    One of the check-off features of the i7-6700HQ-powered VORKE V6 is the support for dual-channel DDR4 memory, meaning that you can install 2*16GB DDR4 RAM stick to the host. On top of that, the 2 M.2 slots bring access to both HDD and SSD memory of unlimited size.
    Dual Band WIFI
    With support for 2.4Ghz and 5Ghz band, it can transmit higher amounts of data, and its naturally less congested.
    Gigabit LAN
    Gigabit LAN can improve the net speed and the performance to a large extent.
    Specification
    General Brand: VORKE
    Model: V6
    Type: MINI PC
    Color: Silver
    Hardware System: Support Windows 10, Linux
    CPU: Intel Core i7-6700HQ
    Core: Quad Core
    GPU: IntelĀ® HD Graphics 530, Nvidia GTX960M, VRAM 4G
    RAM: Dual Channel DDR4 SO-DIMM slot, Support up to 32GB
    SSD: Support Dual M.2 22*80 SSD; one supports PCIEx4 and SATA3.0; another one supports SATA3.0
    Communication 5G WiFi: Yes
    WIFI: 802.11 a/b/g/n/ac, Dual-band Wi-Fi 2.4GHz/5GHz , Dual Wireless antenna
    Bluetooth: 4.2
    RJ45: 100M/1000M
    Interface DC: 5.5mm DC Jack
    HDMI: HDMI1.4,Support 4K@24Hz
    DP: DP1.2, Support 4K@60Hz
    Audio: Mic Jack, Headphone Jack, Optical Jack
    USB Host: 4*USB3.0+2*USB2.0
    SD Card Slot: Yes
    RJ45 Connector: Yes
    SATA: PCIEx4 + SATA 3.0
    HDD: 1*2.5 inch 7.0mm HDD
    Other Features Language: Multi-language
    Power 150W
    Dimensions&Weight Product weight: 1.1110 kg
    Product size (L x W x H): 19.00 x 25.20 x 5.10 cm
    Package Contents 1 x Mini PC
    1 x Power Adapter
    1 x Charging Cable
    1 x English User Manual
    Find out more:https://goo.gl/kMYPF4
    Update:
    $60 coupon:GKBVKV6
      Update:
      we can offer $100 coupon:NAPWDBJL
        the promotion fo vorke v6 is online!don't forget the coupon:NAPWDBJL!
        http://promotion.geekbuying.com/prom...=vorkev6gamepc
          Is it just the barebone or does it have the Ram and storage too?
          If it has the Ram & storage, why call it a barebone?
          tx
            Its got nothing, bare as bone can be....I am led to believe
            The information is what it can do...
              Originally posted by metalhead_rulz View Post
              tx
              just barebone, without RAM & storage. :P
                Vorke V6 - Mini PC Unboxing and Installation Guide
                  Please, current code says final price 339,99$, but when applied it goes to 439,99$. There must be some mistake.
                    hello,which coupon code do you use?
                      Hello,
                      GKBVOV6 which is in line 90 of your google document and is referenced as valid and Discounted price 339$.
                        here is the new coupon: GKBPC2
                          Hello,
                          sorry,it was the mistake we made.
                          now it is the new coupon:GKBPC2
                            Ok, I will not buy it at that price, it's only 8$ under the never-ending "promotion", thank you.
                              thank you,you can look for other products you like.
