Android 5.1.1 (Lollipop) working on S89 (s802)
Originally posted by farpudo View Post
Originally posted by andr3 View Post
I read this too and checked for it, but I can only find the MD5 creation and disabling for backups. Even with the options on (even though it's not a backup), it didn't work. In the settings for the image installation there's only the option of zip-check, which is off by default...
K200_emmc.img and n200_emmc.img works for meIf you see it have some error in the begining but it flash successful.
Originally posted by ivanrandjelovic View PostAGAIN if you see tronsmart logo without boot into system (android) you must do all over again.
Burn from pc
Twrp
Flash boot
Reboot
BUT, I always get the boot logo (tried also tronsmart before) even when going straight for recovery and it seems unavoidable. My cache and data are also messed up as mentioned in a previous post, but changing file system fixes that (I hope).
I tried making my own image replacing the boot.img directly so everything is flashed together, but so far no success (also doesn't pass the check...).
Open for any crazy ideas!
With the instructions in the OP only, got my MXIII S802 (2GB RAM + 8GB Storage) working with firmware: MXIII-G_108L1_Tronsmart, recovery: twrp-2.8.5.0-k200.img, and matricom file in OP. Also managed get root access with KingOroot (not kingroot), however superuser apk does not seem to be managing access at all, all apk's are gettting root access if they require them (not the most secure thing). supersu apk provides option to update binary but dont fancy messing it up. Managed to get adaway and few other root apps working with no problem. note: after done rooting make sure to uninstall both the kingoroot apps as it adds a notification bar.
The unit does not power off but can suspend/sleep and restart. Not had any of the issues with not getting it out of sleep, though i have disabled daydream just incase. For people having issues with getting it out of sleep/daydream, if it indeed has to do with CPU Clock speed, with root access you can download "no-frill CPU-Control", go to settings, include sleep then on main interface set idle clock to then 200mhz and select bootup option.
Oh and thanks OP for the post! if only this box hardware had 1080p x265 encoding it would be perfect with this firmware but hey, still greatway better than stock kitkat.
Please help, I followed instructions EXACTLY how it was pointed here but TWRP says "E:Unable to find partition size for '/boot'" when trying to flash boot.img.
Could someone help? I have a Tronsmart MXIII 2GB RAM / 8GB ROM with "Tronsmart MXIII_115k4_20150603" rom flashed with this new rom "Tronsmart MXIII Plus_108L1_160604"
EDIT: Problem was I wasnt using the correct TWRP file, turns out the correct was "TWRP_2.8.7.0_K200.img". Now booting, lets see if this works!
EDIT2: It appears that everything went very well, WIFI and Ethernet work. Netflix doesnt show up on Google Play (could anyone help me with that?) and cant shutdown device properly, still, I'm happy as I'm able to run lastest Kodi with no problems.
EDIT3: Managed to root with KingOroot. This is terrific.
EDIT4: Ok, biggest problems I'm facing is I cant find a way to get Netflix on the box, cant even download from Play Store, and Antutu is found but cant be installed. I'm trying to fake the device to another editing build.prop but still I cant get it right. Hope anyone reads this could help me.
EDIT5: I managed to download an APK of Netflix from apkmirror and it worked. I still need to find out how to make the device be able to download "not compatible" apps from Play Store.Last edited by ochentay4; 26 March 2018, 13:26.
just wanted to stop in and say thank you, ive managed to now update my old s802 box to run this android 5.1.1 which it does very well! the only issue i seem to face is i have no working wifi
Originally posted by Dandroid534 View PostYou can probably flash other WiFi drivers as well if WiFi isn't working right.
many thanks and all the best
paul
Hello, I would like to thank you all. with all the information here, I manage, with several tries, to put Lollipop 5.1.1 on a Starstream X4 2g/8g
It works with some minor issues.
1) I use AV port on my tv with the android tv box. The settings: NTSC 480 and the Screen Zoom 80% information are lost each time the device is shut down.
I don't know if there is a Startup app that i could program the clicks to get NTSC 480 on startup? Or something else I could do to fix it.
2) The remote that came with the box doesn't work. Thankfully, I have a Beelink gt1 ultimate and I use that remote to navigate with the modified
Startream X4
3) In order to shut down the device, I have to select (suspend) choice. Using the shutdown option reboots the device.
I welcome any suggestions to help me fix the tv box. Beside that, I'm happy, some apps that did not work under kitkat 4.4 now work great.
The device has now a second life.
Thanks to all your good work
I installed this rom https://probox2.com/category/probox2-ex-firmware-3/ all is working except power button and HDMI-CEC. Who knows hot to fix it. this problem in kernel or boot.img?My Device: Tronsmart Vega S89-H [ROM] leolas 1.1.0
Originally posted by Dope101 View Postjust letting you guys know that lollipop works on this box,probably any s802 box for that matter.
the trick is to flash matricoms boot.img (pulled from their firmware) in TWRP after you flash a .img firmware with the USB burning tool.
https://drive.google.com/open?id=0B1...ENxakpweFRaRHM
flash a S812 lollipop rom with USB burning tool
copy abduls TWRP recovery (k200) and matricoms boot.img to external SD card
load abduls TWRP recovery on external SD card with toothpick method
in TWRP flash image (boot.img) from external sdcard to boot
reboot
first load takes a while, but it will boot, be patient.
firmwares i tried that worked.
MXIII-G_101L1
Tronsmart MXIII Plus_102L1_150812
x8-h-plus-lollipop-rc2
boots,but WiFi,Bluetooth,Ethernet all dont work, so its useless
1. flash a S812 lollipop rom with USB burning tool
man soll ein S812 lollipop rom flashen, (aber welches wo bekommt man das her und wiso ist hier kein Link dazu?)
mit hilfe des USB burning tool, (und wider kein Link. Ich habe es dann mit Google versucht und Amlogic_USB_Burning_Tool_v1.2.8.0817 gefunden, ist dass das richtige?)
2. copy abduls TWRP recovery (k200) and matricoms boot.img to external SD card (TWRP recovery wo ist der Link?)
3. load abduls TWRP recovery on external SD card with toothpick method (was ist bitte die toothpick method?)
Wieso ist nicht alles zusammen in ein Link und warum ist die Anleitung so unverständlich?
Bitte um hilfe.
There are currently 3183 users online. 0 members and 3183 guests.
