MK908 and PPPoE
    MK908 and PPPoE
    Hi there,
    recently I bought the machine and I wanted to connect it to the internet using PPPoE in settings. WiFi worked OK (i was connected to the router) , but when I filled the setup screen for PPPoE, the profile name was not shown at all in the menu level above (it was blank but available to be chosen) and if I choose that profile, it doesnt work. Is it an issue of 4.2.2. or is it an issue of MK908 or I messed up something...
    Cheers...
    Originally posted by inverse_g View Post
    Hi there,
    Cheers...
    I had the same problem, it is because you did not save the profile correctly
    Try adding again, and this time click the Save button!
      Thanks, problem solved!
      I am new to the Android system and the only way to save profile was to press RMB, let the system warns whether I want to save or not the profile. there was no save button on the submenu though.
      Cheers!
