Android box
    Android box
    Hi could anyone point me in right direction I have a c918 android box stuck on red light
    first try another poweradaptor..
    if that's not the problem.. try using the reset button like..so:
    unplug powercord...hold reset...wait 5 sec..plugin power...keep holding reset for another 10sec before releasing
    you should see:android recovery...try emty cache first...if still no boot : factory reset ( will delete all data)
    if that doesn't work...see:
    opening the tvbox..and comparing your motherboard with the many pictures
    hopefully there is a firmware for your box
    goodluck
      Ty mitchell you this worked a treat
