Need help creating firmware!
Re: Need help creating firmware!
Originally posted by Verevka View PostI try to create a firmware cwm, after the installation is not working wifi (does not specify IP ), who can give all the symlink used in system.img? (Sorry for my english!)
Usage:
flash_image mtdname file.img
Example:
flash_image system system.img
Originally posted by leolas View PostIt is easier to flash the syste.img like a img file with the bin flash_image included in all my cwm rom zip file or in fun cwm recovery in /sbin/. It is made by fun, so thanks to him.
Usage:
Example:
leolas
Originally posted by Verevka View PostThis is not what I want to do the right thing!
What do you want? Flash a system? This is the easy way.
Want the permissions of the files in system.img? Mount system and:
ls -Rla /system>system.txt
What did you make? A port of other device? Or a mod of your stock rom?
I don't understand well, you want to make a zip flashable by cwm of neomode v1.3 rom, and you have androtab cwm recovery installed. Am I right?
Or are you modding neomode rom?
Originally posted by leolas View PostI don't understand well, you want to make a zip flashable by cwm of neomode v1.3 rom, and you have androtab cwm recovery installed. Am I right?
leolas
Mods will be laterAttached Files
Originally posted by Verevka View Postyes, cwm install. I want to make a zip flashable by cwm of neomode v1.3 rom
Mods will be later
package_extract_file("system.img", "/tmp/system.img");
run_program("/sbin/flash_image", "system", "tmp/system.img");
The same with the other img files, like you must know there is no way to change parameter from cwm, at least I don't know it.
Originally posted by leolas View PostI never try to det permissions for filed manually, so I suggest you try to use the bin flash_image. In cwm updater-script the command will be:
leolas
Yes, but I think is easier mount system.img, modify in it all you want, add busybox, the links, init.d, etc... Then unmount it, check it, and choose any way, cwm, rk flash, etc.. to flash it.
I think wifi dont work for a permission issue or missing symlink, but is so difficult to find, and more from a mobile phone.
There are currently 3948 users online. 1 members and 3947 guests.
