OUKITEL C8 Full Specs gathering, 8 features to know all about it
Name:	OUKITEL C8 5 COLORS.jpg
    Full screen smartphones have been quite popular in market. Different manufacturers like Apple, Samsung, Huawei, Xiaomi, all have their own opinion about full screen. However, OUKITEL isn’t so far behind. OUKITEL has prepared different kinds of devices featuring full screen. For entry level smartphones, OUKITEL released the OUKITEL C8 as a star product to lead the infinity displayed smartphones.
    As a star product, OUKITEL C8 has got 8 features that makes it a great choice.
    First, Latest 18:9 Full screen. C8 is the first entry level smartphone that designs display to be 18:9 aspect ratio. Slimmer body allows you to hold it in one hand but views more.
    Second, 5.5 inch HD display with LTPS tech. High definition screen and Dragon Glass processed by LTPS tech, showing bright and vivid colors on the slim screen.
    Third, 3000mAh big battery. It will support a whole day use.
    Fourth, 13MP+5MP dual cameras. Entry level smartphones can also take great photos. OUKITEL optimized the camera to show natural colors.
    Fifth, 2GB RAM+16GB ROM with 64GB expandable memory. No pressure to run multi-tasks.
    Sixth, Press fingerprint unlock. To protect your data, fingerprint lock is a must.
    Seventh, 5 fashionable colors. Rose pink, midnight black, orchid purple, sunny gold, and sky blue. Looking at these colors, have a whole day good mood.
    Eighth, Surprising wallet-friendly price. OUKITEL C8 is only sold at $69.99, quite competitive price among same level. It beats other smartphones with 2GB RAM and 16GB ROM not only by its price but also in design and performance.
    To know detailed specs about C8, check below:
    Colors: black, blue, pink, purple, gold
    Display: 5.5”1280*720 pixels, 2 points IPS 18:9 display
    Cameras: 13.0MP &flash light support + 5.0MP
    Battery: 3,000mAh removable, 5V/1A charger
    Dimensions & Weight: 147*70.5*10.2mm
    OS: Android 7.0 Nougat
    Chipset: MT6580A quad-core 1.3GHz Cortex A7
    Memory: 2GB RAM+16GB ROM, 64GB expandable
    Connectivity:
    Network: GSM: 850/900/1800/1900MHz;
    WCDMA: 900/2100MHz;
    SIM Card: 1 micro+1 nano+1 TF card
    WLAN: 802.11a/b/g/n/, Support Hotspot
    Bluetooth: support, Bluetooth 4.0
    GPS: GPS/AGPS/GLONASS
    USB: Micro 5PIN
    Earphone jack: 3.5mm
    OTA: support
    FM Radio: support
    Sensors: Fingerprint sensor/Gravity sensor/procimity sensor/Light sensor/Notification LED
    OUKITEL C8 is devoted to be a best seller in the coming hot season. Now it is accepting pre-orders on OUKITEL Offiical store. Click here to check details about OUKITEL C8.
    http://oukitel.com/
    Hi ,
    nice Phone , but what GPU is used Mali720MP2 ??? , or what .
    OUKITEL.com says the Resolution is 1280/640 , what is correct ???
    thanks / gefattern
      Hi gefattern,
      The GPU is a Mali-400 MP1 and it should have a HD Screen.
      Maybe I get one in my hand, then you can read how it performs after my review.
      Don't forget it is an entry level phone for about 70 Euro.
      JD
