Firmware aml_7.1_s912_q9377-H96PROPLUS_KDMC_mac-20170826
Oh and FYI
The H96 Pro+ is made by Shenzhen Goodidea Technology (hcygood.com) and by default come with the 4k branding
Gearbest opted for free oem branding and had alfawise printed on the top
There are multiple options 16-64gb DDR4/DDR3 etc
or no choice on the ram and you get what you get
nand you get what they have on the day
ddr3 is still being made mine was built on the 08/08/2017
Code:H96 PRO+ PCB CZ-S32-v2.2 20161012(A15) QL 1730 JOB20170808 3+32/9377 1 x amlogic S912 OCTA-CORE BODGHN01404 J-TNA346.00 1 x 32GB Toshiba 19nm THGBMBG8D4KBAIR 170821AE EMMC HS400 V5.0 Read 270MB Write 90MB 1 x Fn-Link 8223A-SR COB009 1732 (QCA9377 433Mbps 1T1R 802.11a/b/g/n/ac BTLE 4.1) 1 x RTL8211F H6120H4 GH25 Gigabit Ethernet Transceiver 1 x GL850G HH4JB05Y22 713SGF9891 Genesys Logic 4 Port USB 2.0 Hub 2 x 1GB SpecTek 512X16DDR3 HL - FC4F 1708 / DY6L 1704 (SpecTek State 1600MHZ DDR3 1.5v) (rebadged Micron 512x16 DDR3L 1866 CL13) 2 x 512MB Micron 6EN77 D9SDD 3ZRJ (256X16 DDR3L 1866 CL13) D9SDD full PN=MT41K256M16LY-107:N
then another 12% or so on the system log
removing the SubtitleService from /system/SubtitleService and a reboot fixed this
log isnt going mad now either
Im not sure if this is a problem with the H96 Pro+ firmware (most prob not)
Its most prob down to the junk i removed below on first setup of android)
Code:/system/presinstall = all deleted /system/media/org.xbmc.kodi.zip = deleted (60mb of addons) /system/app/appinstaller /system/priv-app/dlna /system/app/filebrowser /system/app/gmail2 /system/OTAUPGRADE /system/app/miracast /system/app/music /system/app/pppoe /system/app/videoplayer /system/tts/ all deleted apart from gb and us changes to build.prop en-GB dd-MM-yy #ro.platform.keepbackground.app=com.droidlogic.PPPoE #ro.platform.has.pppoe=true Then reset to factory defaults straight after doing this
Something else worth mentioning Linux has an mmc HS400 corruption bug so limits maximum speed to 200mb as a lazy fix
Code:EMMC [ 2.395069@1] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error [ 2.659473@3] emmc: try set sd/emmc to DDR mode [ 2.659959@3] emmc: new HS400 MMC card at address 0001 [ 2.660587@3] emmc: clock [B]100000000[/B], 8-bit-bus-width SD Card [ 14.529170@4] sdio: clk 200000000 SDR mode tuning start [ 14.531451@4] sdio: new ultra high speed SDR104 SDIO card at address 0001 [ 14.531459@6] sdio: clock 200000000, 4-bit-bus-width Would read if running at HS400 [ 2.659473@3] emmc: try set sd/emmc to DDR mode [ 2.659959@3] emmc: new HS400 MMC card at address 0001 [ 2.660587@3] emmc: clock [B]200000000[/B], 8-bit-bus-width
Are there still issues with hidden menu's like "HOME" to change launchers,
Air mouse speed settings only in hidden menu,
LAN Connection not connecting until one reboots,
Bluetooth bombing out?
Reboot softkey shutting down unit completely?
Originally posted by leptdre View Postis the UI 4k or not. i wasn't able to set the UI to 4K , the HDMI signal is 4k 60 FPS but the UI is 1920x1080 in cpu z and kodi ???
but it has to scale the ui or everything will be tiny
its set at ro.sf.lcd_density=240
thats just for the ui
video's and such are 4k
you need the latest android tv youtube apk
com.google.android.youtube.tv 2.01.04
i used this one checked it at virus total but can never be 100%
https://www.apkmirror.com/apk/google...-apk-download/
standard youtube for android only gives me 1080p
this gives me 4k even though im at 1080p looks very crisp
it stops the youtube link on the launcher working though so you have make a new shortcut
also not sure how to hide the top bar atm
Hi,I haw flashed this rom on my h96 pro plus ddr3 3gb 32gb.I installed Kodi krypton 17.4 and put the ares build,when I boot Kodi I haw pop up error : system proces error,and kodi freez up,buth in background build is working,the all system is freez and I must turn off the device.Haw some solution for fix this problem?Thanks..
There are currently 3259 users online. 1 members and 3258 guests.
