Help with Mecool m8s pro
I installed the Nexus firmware update for my device last night, but didn't like it. Netflix kept giving me an error code and wouldn't connect. Plus there were other problems I had. The main thing was Netflix though. I tried reverting back to the origianl firmware but it would only load Nexus after factory reset. I tried a hard reset using my micro SD card. I wiped the system, and now when it boots it is stuck on Nexus. My remote won't do anything and I can't get into my device. Please help me. I don't want to have to buy a new device because I only bouth this one a month ago. -
Guest
A factory reset won't revert back to your original OEM firmware, and you've erased the system partition and so an OTA update is now impossible. You need to flash it back using USB Burning Tool or BootcardMarker with the burn package (.img file). Links are in the original post for my custom ROM.
There are currently 3140 users online. 0 members and 3140 guests.
