Pipo M7 Pro RileyROM 1.2
    This ROM update is based on the official firmware from the Pipo site dated 7/29/13
    Here is a link to the official site I get the firmware from:
    Official Firmware
    It is rooted with 2,4,6 or 8gb user app space, init.d support, Google Play Store fixes. And this ROM comes with an awesome bootanimation from Tattman65. Also, I included the generic CWM Recovery as default...if it doesn't work for you just use the included stock recovery. If you want to try future flashes with CWM you can use the template I provided (readme). You MUST use the flash tool on this ROM the first time.
    Here is the download link:
    3G Version
    WIFI Only Version
    Here is the link to the feedback thread for this ROM:
    Feedback
    If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
    Randy
