Here is a link to the official site I get the firmware from:
Official Firmware
It is rooted with 2,4,6 or 8gb user app space, init.d support, Google Play Store fixes. And this ROM comes with an awesome bootanimation from Tattman65. Also, I included the generic CWM Recovery as default...if it doesn't work for you just use the included stock recovery. If you want to try future flashes with CWM you can use the template I provided (readme). You MUST use the flash tool on this ROM the first time.
Here is the download link:
Download Page
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
