T96 PRO T96N+ RK3328 TV Box - 2GB RAM + 16GB ROM Android 7.1 + Quad-core Cortex-A53 + 4K VP9 H.265
    ● It runs on the Android 7.1, which is stable to use. You can connect to a world of content and entertainment at home with the box
    ● 4K VP9 can help you save 50 percent bandwidth resource, and deliver razor-sharp detail and vibrant images
    ● A high performance of Quad-core Cortex-A53 CPU can play a wide range of games
    ● 2.4G offer a more stable signal for you to enjoy higher quality video experience
    ● HDMI 2.0 is a faster way to send video and audio output to your TV
    Gearbest
    Today we can have a close look at the T96 PRO T96N+ RK3328 TV Box - 2GB RAM + 16GB ROM Android 7.1 + Quad-core Cortex-A53 + 4K VP9 H.265
    Model: T96N+
    Type: TV Box
    System: Android 7.1
    Processor: RK3328
    CPU: ARM Cortex-A53
    Core: 1.5GHz,Quad Core
    GPU: Mali-450MP2
    RAM: 2G RAM
    RAM Type: DDR3
    ROM: 16G ROM
    Max. Extended Capacity: TF card up to 64GB (not included)
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: 4K,AVI,ISO,MKV,MOV,MP4,MPEG,MPG,WMV
    Audio format: AAC,FLAC,MP3,OGG,RM,WMA
    Photo Format: JPEG,JPG,PNG
    Power Supply: Charge Adapter
    Interface: AV,HDMI,LAN,SPDIF,TF card,USB2.0,USB3.0
    Language: English,Japanese,Multi-language,Spanish
    HDMI Version: 2.0
    Other Functions: 3D Games,3D Video,DLNA,ISO Files,Miracast,NTSC,PAL
    External Subtitle Supported: No
    HDMI Function: HDCP
    Power Consumption.: 8W
    RJ45 Port Speed: 100M
    System Bit: 32Bit
    WiFi Chip: RTL8189
    System Activation: Yes
    Power Type: External Power Adapter Mode
    Product weight: 0.1030 kg
    Package weight: 0.3500 kg
    Product size (L x W x H): 10.00 x 10.00 x 1.80 cm / 3.94 x 3.94 x 0.71 inches
    Package size (L x W x H): 18.00 x 12.00 x 4.00 cm / 7.09 x 4.72 x 1.57 inches
    Package Contents: 1 x TV Box, 1 x Remote Control, 1 x Power Adapter, 1 x HDMI Cable, 1 x English User Manual
    So let's have a look
    The Box, Woodgrain finish hmmm
    Peak in side
    What's in the Box
    Ports
    Casing, pop the blue bit if it gets to hot I guess.
    Under Side of PCB
    Top Side Of PCB, actually faces down in box, thin small heat sink
    More Later
      We have Root no SU, No Upper Notification or Lower task Bar
      Runs warm, poor Heatsink, facing down with not a lot of air circulation. temps middle upper of screen
      No Bluetooth. 2.4Ghz wifi and fast lan
      Let's look further into UI and Test,
      UI
      BSCH that works well
      DRM
      Another pre-installed System info
      Ram and Storage Truth
      CPU-Z
      A1-SD
      Unit Is ok needs some tuning and tweaking here and there
      WiFi and Ethernet OK for what it is
      Much the same as others in this field I find at present..
      Thanks To Gearbest
