mxq pro 4k rk3229 6.0 - Urgent Help
    Hi Experts,
    I need your immediate help once again
    I have mxq pro 4k rk3229_6.0 box as attached . https://imgur.com/a/ovZzF
    By mistakenly I have done wrong firmware of rk3229_5.1 on that box. Now
    box become dead. Light Red light on when I power on. Not connected to my PC to do the right software.
    What I do now please help?? Waiting my friends help
    stuck now.. wrong firmware makes my box dead showing light red light.. . not connecting to pc for doing the correct software
    experts please help for that issue at least tell me which two pins on the nand to be joined. thank u..
      Hi youbee ,
      first we need Pictures of the PCB , good Quality , nearby , both sides .
      We need the right FW for your WifiChip , hope it helps / gefattern
        Hello,
        Here you find the Firmware you need for your Box.
        Just Install with the PC and all should be good then.
        Neomode
          problem solved. Thank youl
