Lava Xtron RileyROM 1.0 [Without HDMI] Feedback Thread
    Just download it again. It's still on our server.
    Most of my ROMs contain that same CWM file.
    Randy
    I still have it.. but after flashing, I'm not able to get into cwm or stock recovery..since i didn't know the 3 button combination, i'm trying rebooting apps.. may be the 3 button combinations would help?? If you can tell me the 3 button combination, that would be helpfull a lot as usual....
      Look in you app drawer for an app called Reboot. It will reboot your tablet into recovery.
      Randy
      Randy
        #Try use app => HoloReboot, QuickReboot, etc.
        #Manual method to CWM recovery mode.
        1. Hold to press "volume+" button.
        2. Follow to Press "power" button = 5 sec.Then release "power" button.
        3. Wait for Screen boot up with logo then release "volume+" button.
        4. If no Screen boot up, try again and try again.
        good luck .
          thanks
          rom is very nice... found impremvment in battery backup.. the wifi is a buggy (need to fix that)
            Thanks to Freaktab member pradipsoman , here is a new ROM for the Lava Xtron tablet [NOT PLUS] based on an official firmware release.
            This ROM is:
            Rooted
            Very little debloat
            Expanded Ext4 System.img
            2, 4, 6 or 8gb user app space (I have no clue how much NAND flash you have, so maybe 4 or 6 would be the limit)
            CWM Recovery
            Bootanimation by Tattman65
            Reboot app by Petrus
            CWM Flashing Template by 900Supersport
            First Time User's Guide by Pr0xZen
            Here is the link to the ROM download:
            Download
            If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
            "thanx for evertyhing...but how do i flash dis rom..my tab s not rooted...plzzzz help me...please reply."
              Just read the First Time Users Guide within the zip file. It should cover everything.
              Randy
              Randy
                I decided not to wait.
                I have put together a very basic rooted ROM with very few other tweaks.
                Go ahead and see if this one works for you.
                Just download from the same link on post #1.
                sir...how do i flas d rom...plz bro...
                  Did you find the guide I mentioned?
                  1. Install the Rochchip drivers as explained. You might have trouble if you have Windows 8.1.
                  2. Open the flash tool in the ROM kit and connect your tablet.
                  3. Make sure USB debugging is turned off.
                  4. See if the flash tool sees your tablet in mass storage mode.
                  5. Click reboot to flash mode on the flash tool.
                  6. If that doesn't work...use the alternate tool I provided...the RKBatchtool. If there is a pink box, click switch.
                  7. Erase IDB.
                  8. Flash ROM.
                  The tablet will boot to recovery when the flash is complete. Then it will reboot to the system after the partitions are formatted.
                  That's it.
                  There is much more info in the guide I told you about.
                  Good luck.
                  I have to sign off for the night. If you need further assistance, I'll be available again tomorrow US Central Time.
                  Randy
                  Randy
                    Riley Sir, By default your ROM creates 2GB for internal memory and 4.20GB for User available memory. I want to have 1.5GB for internal and rest for User available. Is it possible for you to modify the parameter file so as to obtain above requirements? Thanks.
                      7. Erase IDB.
                      8. Flash ROM.
                      That's it.
                      Good luck.
                      Randy
                      Thanks for ur reply sir...
                      but I am using windows xp and when I cnnct my lava xtron d flash tool says no rkandroid rock usb...
                      I am frm india and I cld not understand installing d rockchip drivers...
                      could u plzzz help me with a full video or so...plzzz sir..
                      I really want to root my device ...thanks again..
                        7. Erase IDB.
                        8. Flash ROM.
                        That's it.
                        Good luck.
                        Randy
                        sir..i think i have bricked my tab....
                        when clicking on flas tab it said download failed and now my tab is not booting..(poweing on)
                        as u have mentioned there is no reset hole...
                        wat should i do...???
                          1. Hold press power button = 10 -20 sec to sure tablet is power off.
                          2. Hold press vol+ button and connect usb cable to PC.
                          3. Open RKAndroidtool will see "Found RKAndroid Loader Rock Usb device"
                          4. Erase IDB.
                          5. Flash Rom.
                          note.
                          USB must is 2.0 (don't use USB 3.0).
                            4. Erase IDB.
                            5. Flash Rom.
                            note.
                            thank you sir...ill try...
                            but d last time i clickd on flash rom..it said "download failed"...wat does dat mean???
                            (or)how must i use d flash tool...
                            thanx again sir...
                              thanx again sir...
                              Try to change parameter file before flash rom.
                                how to do that sir???sorry...but i am not a pro in this...
