If you suddenly encounter a problem, your tv box Zidoo H6 Pro does not turn on, Android does not load, there's no Zidoo logo, and the usual way to reflash does not help, try the following method to decrypt TV set-top box:
To do this you will need:
- Program for recording - PhoenixCard
- Firmware itself - Firmware v1.0.25 for Zidoo H6 pro
- microSD card
1. Extract both files from the archive
2. Run the PhoenixCard.exe file
3. From the drop-down box, select the microSD card, click DiskCheck, and tick the Product.
4. Click on Img File and select the firmware file that you downloaded from the link above.
5. You can press Burn and wait for the end of the recording, then you should safely remove the memory card.
6. Disconnect the Zidoo H6 Pro from the network, disconnect all devices from it to USB and turn off the power.
7. Insert a memory card, connect to a monitor or TV, and power up. The installation process starts with the green bar, wait until the end, then turn off the power and remove the memory card, then you can turn it on and on again.
Guide for unbrick zidoo h6 pro if your android tv box is bricked.
Source: Zidoo
Model: ZIDOO_H6 Pro
Version: v1.0.20
Download:
http://www.mediafire.com/file/cj546u...OTA_V1.2.0.zip
MD5:5E7E9EB86058175722E5546141447D3E
How to upgrade
The way is similar with X9S
http://www.zidoo.tv/Support/guide/guide_target/7kv1voas1D1KKmVViAFMcQ==/guide_faq/CN6lY0XMyIg=/faq_page/9nCdOWqz+dw=.html
Update list:
SYSTEM
1,Fix mouse judders after scale the screen size smaller
2,Add auto-framerate-switch function
3,Optimize the compatibility of Kodi
4,Optimize the stutter issue of some videos in Kodi
5,Fix dts-hdma、truehd audio can't downmix to 5.1
6,Correct the off-color-to-red problem in Kodi.
7,Fix Douyu apk unexpectedly terminated
8,Fix HDMI thoughout changed to PCM unexpectedly after turn on H6 and TV
9,Fix the space character caused browse fail in samba and nfs.
APP
10,Add a icon for Poweroff apk
11,Player added the Italian language
12,Optimize the subtitle in Player
13,Add a Mediacodec framerate switch in QuickSettings
14,Add a function that hold the mute key to call a dialogue for image quality adjustion
15,Add a rotate image function in Picturemanager, and improved the sharpness for animation affect
Source:
http://forum.zidoo.tv/index.php?thre...oo-h6pro.7202/
Model: ZIDOO_H6 Pro
Update list:
1. Solved the issue that UHD movie can not play.
2. Added the function of Android TV remote Control.
3. Solved the issue that Netflix freezing.
4. Solved the issue it can not adjust the volume when YouTube loading data.
5. Built-in zidoo picture manager, remove the Android native picture browser.
6. Solved the issue that individual MKV video can not play.
7. Solved the issue that the proportion error of individual film playback.
8. Solved the issue that individual machine prompts with CVBS plug in, plug out.
9. Added multi-font support on external ass subtitles.
10. Added function of the same direcotry on subtitles to download video files.
Download url:
http://www.mediafire.com/file/y72qg4...1.0.13_ota.zip
MD5: b59cb525ed294faf36e6aa0c633f089f
Update style:OTA
How to upgrade
Source: Zidoo
Version: v1.0.10
Updated list:
1.Netflix supports 1080P playback.
2.Youtube supports 2k、4k playback.
3.Solved the freezing issue on such bbc news、vimeo, etc applications.
4.Solved the issue that can not save when HDMI setting into 4k up to 60p.
5.Solved the issue that some screens display in 4:3 size when TV turn on.
6.Solved the wrong color issue when playback hdr video on kodi
7.Optimized the connection tips of bluetooth remote control
8.Fix the Launcher app open applications ui, the fast press the back button, the ui does not display
9.Optimized the freezing issue when playback truehd、atmos videos via smb network.
10.Solved no sound issue on some ac3 videos
11.support root(just need install super-su).
12.Solved the issue of individual device that shows tips repeatly with cvbs plug in、cvbs plug out
Download url: http://www.mediafire.com/file/cd50kx...1.0.10_ota.zip MD5: 924ae598ba65d2cb0740c89f271c405b Update style:OTA How to upgrade: http://www.zidoo.tv/Support/guide/gu...dOWqz+dw=.html |
