Low resolution (800x480) ROM available for MK908?
    Hi there,
    Is there a low resolution ROM available?
    As i am trying to adapt a MK908 to my Car headunit (Alpine) i wonder if there is a version supporting the lowres of my IVA-W520R (800x480)?
    There were tablets having this resolution available, so this must not be impossible.
    Can this be done using any config file, so i do not have to make my own ROM?
    Best regards
    Jürgen
    all the stock roms have a low-resolution mode. I don't have anything good to test it on, so I can't tell you how well it works.
      Hmm...
      I thought they all were downscaled, because all the lines look very thin and 'flicker' when scrolling.
      BTW, what is a 'stock ROM'? Mine came with a rooted jj'something'-ROM.
      Is this a stock one? I don't think so.
      I looked1280x768 downscaled to 720x480. But this is just what i felt when looking at it.
      Maybe its my 'high-quality' China-7"-touchscreen-monitor for massive $40,-...
        Just digging it out...
        I need a 480 interlace output as my HDMI/VGA converter only outputs what it gets on the input side. So if i do not feed him interlace i won't get it on the output.
        Any chances of geting a ROM for this?
        Or is there any other way to get a good quality picture on a scart input?
