What box please?
    What box please?
    Hello.
    Please, give me an advice. I needed a 905x processor box - it runs on it as the only application I need.
    It's for my father. So I would need it to be overall stable - it will not install a new ROM.
    To have a RAM of 2 Gb and at least an Android 6. And most preferably a root for Titanium backup.
    I have a seamless X95 Pro-only support here has none.
    Thank you in advance for your reply.
    Hello,
    Take the X96 TV Box.
    It has an S905x CPU and runs real smooth.
    Regards
    Neomode
      I've been looking at this model yet. Is fine?
      Thank you.
      http://www.****.com/itm/Beelink-MINI...0AAOSwxX1Z0cas
        Hello,
         Not bad Hardware the same as ProBox2 Air.
        But they have 2 Models with different Wifi Chips.
        This will make no difference at all.
         Neomode
          And how do I know the difference? :-)
            I've still found this box. It's good? Can anyone recommend?
            https://www.****.com/itm/Q-BOX-S905X...IAAOSwiA9ZYAHg
