Brick my Box Alfawise H96 PRO plus
    Hello, i have more then one Boxes here. Now i have become a new box (looks same as the other) but this box have 2 different.
    1. the new box have a sail behinde
    2. new Box have write : AndroidOS 7.1 (other boxes you see Android OS6.0)
    Ok, the new box is come now and i will flash the new OS from Stock 7.12 but then the Box brick with stock rom. Next step is i will flash the box per USB but i become a error :
    Stock Rom will come:
    Get Key Failed (1%)
    then i use a custom Rom:
    flash it at 98% then i become an error:
    U-Boot/ partition system/ Verify Partition/ Error result
    If i make a recovery file to sd card, i can go to twrp but if i do anything i can do nothing why system and data is 0.
    Everybody can tell me what can i do now !?
    How can i unbrick the box now !? This box is realy new, i unpack it and flash it directly.
    Another guy have write (in another thread) that he have many boxes and the new Alfawise Boxes you only can flash with a Jig Cable but i cant thing that i have brick it why i never can make a update in future with this box now.
    For all other peoples, If you buy a new box from Gearbest, look behinde the box, if it have a seal and have under the box Android OS 7.1 you never flash a new OS with SD or with another way if anybody can unbrick the new boxes!!!!
    If you not trust me, make it and only jesus can help you a dead box bring back to live
    for all other peoples .....
    PLEASE HELP ME !!!!!
    yiiiiiipyyyyyyyyy
    Now i have a bootlogo again and just in the moment the box boot again.
    For all peoples who have this Box with this fu... Problem, here i a way who it can be that it work for you.
    1. you need a USB "Male2Male" cable
    2. USB Burning Tool 2.08
    3. This Firmware:
    https://mega.nz/#!QVVWhQrB!3S_pYk0zi...8vWfXhrRq70Xnk
    4. Load this FW in USB Burning Tool and change settings to:
    Erase Flash --> Force Erase and click on "Erase Bootloader"
    5. Load this FW as image and click start
    6. connect your box to PC and let it do it.
    7. first time on 95% its fail, so click reset button on box for 5 Secounds
    8. let the box flash again
    9. now the box will flash without errors
    10 Have fu... Fun again
    I have found this Link here in Forum, thanks for the guy who have upload it (before i forget it )
    My english is not the best so its hard to found the right way. If anybody cant understand my way and only speak german please write me a pn i will help you in german.
    //Edit
    only Problem what i have now is that the box make a restart from self if i install apps or do anything. I dont know what it is ...
      See time and keep at works another trick is to start the burning tool and then connect the box Glad ya got it going.
        Yes, problem is, with the new boxes from GEARBEST with a sail and with a Android 7.1 under the Box only this Firmware Works for me. I have Test the new fw too but on 95% i become a error code (UBoot Error) and Box don't boot anymore.
        Thats more then Shi... what China make, why they do that? Its realy hard if never can make a Update without brick his Box.
        I have Test maybe 20 custom fw ans 10 Stock fw for H96 Pro Plus but nothing work for me only this file. I first have Flash with SD Card, later with USB burning Tool only but nothing work only this file.
        Maybe there is adaware in the Box and they don't wont that we can change it, maybe the wont that we brick the boxes i realy don't know why they do that.
        The biggest problem is not to flash the Box, the Problem is the fw that is another but with the same fw sometimes i must Flash 5 Times if the fw is Flash without problems.
          Wolfsstolz,
          The error code at 95% loading sounds like you have an bad firmware download - try downloading it again.
          Try downloading the firmware from a different source. (Search GoOGLE)
          Try downloading using a different browser.
          If you are downloading it with a download accelerator program, you may need to reduce the number of "parts" used for downloading... or use your Internet browser, instead.
            Originally posted by wolfsstolz View Post
            yiiiiiipyyyyyyyyy
            3. This Firmware:
            //Edit
            I have same problem with you i can't install any stock or custom firmware its stuck at %95 everytime. I try many solutions on the forum and google but nothing help me i think we need solution not exist. My tvbox not booting anymore.
              deviltheturtle
              all the way you do now. I did it
              and I had satisfaction
              http://freaktab.com/forum/advertiser...t-sur-freaktab
              you have 3 way to solve your problem with MAC 0
              1) impossible for you to install the rom that starts with amgl-s912 --------- mac 20 8 2017. you need q201_937-userdebug. and also all members who have mac 0
              1) not open a discussion on the website gearbest
              to do all the work on the freaktab forum
              a) send a PM to
              CSGearbest
              ADVERTISER
              b) or open a new topic
              http://freaktab.com/forum/advertiser...a/gearbest-com
              you explain your problem
              2) you can install the
              TX8-TANIX-20170815 s912
              super my problem to me I did not sound and I'm not the only one
              http://freaktab.com/forum/tv-player-...tanix-tx8-help 60 degrees
              b) install the superceleron rom
              no installation problem
              gorgeous smooth rom 65 degrees
              my problem on my box it will hang after a certain time
              c) I try the
              iron + s912 android 7 s912
              Magicsee.IRON-Plus s912
              practically all the boxes 912
              to advise against
              d) if you have a rom already to install try the ota it starts with q
              q9377-ota-S912-20170929.rar
              for Russian
              puts the link of the site on chrome and translator. for me fr ru or fr ang
              good luck . this box has no name. no name of the company. who make it? no rom. nothing
              for the rest of the members who have not had the chance to install the rom
              for reasons that are not MAC 0
              always check if the MAC has a number and the KEYS has a number
              or the box is empty
              there is no installation problem for roms aml_7.1_s912_q9377-S912_KDMC_mac-20170908 for stops at 7% solution is on the forum . no relationship with rom
              my box is in the trash
              goodbye
              more than Alfawise.H96.ProPlus + finished my problems and good luck
                Amlogic Usb Burning tool 2.1.2:
                https://mega.nz/#!i8pxACKC!EIP9DucLY...7-j3r-NKDBEjFs
                TF / SD Graveur de carte 2.0.3:
                https://mega.nz/#!SowFiSID!mEk8gp5qN...xYS5xviDNSUdE8
                  yiiiiiipyyyyyyyyy
                  3. This Firmware:
                  //Edit
                  hello, it's not working for me everytime it block at 95% even i reset during 5 sec etc ... i think ther is no solution
                    hi, i brought an alfawise 96 pro at the fall of novembre, put your android tv rom and brick it
                    I tried a lot of kind soluce but i's never work. When i do a short cut on the nand, their is not the famous sound and i think that the reset failed.
                    this is the mother board ;
ID:	695534 the nand is a Sandisk SanDisk-SDIN7DU2
                    perhaps another pin than the classic 29/30 ?
                      Hi ,
                      did you tried it that way :
                      good luck / gefattern
