Problem with H96 Max and HEVC live stream
    Hello everyone!
    I've recently bought a H96 Max, comming from a Mecool BB2 Pro, and it's a real power house.
    The only problem is that I just can't play 1080P H265 HEVC live channels from my IPTV stream.
    They play just fine on my smartphone and my Samsung smarttv using SSIPTV or any other, but I can't play properly on the H96 Max.
    There's only sound and 1 image frame appears on the screen every 3 seconds.
    I've tried SC rom using Android 6 and 7.1.2 and the original rom, no success.
    I've bought a 5v 5A power supply, still no success.
    It is known that lowers specs boxes can actualy play those streams, like the new Tanix TX3 Mini.
    What could be happening? I really like this box and want to keep it!
    Thanks in advance.
    HI haraferraz , i tried it with SmartIPTV and it works fine, also 2160p no complications. I've the 7.1 from SC installed.
    I dont know but maybe its a codec problem. you can try to install the vlc app for its codecs
      Some talk about it here
      Needs better firmware still waiting
        Well, I don't understand why I can play downloaded HEVC videos but not my live stream with the same specs.
          Was that streams HEVC H265?
          I'll try with SmartIPTV.
          I already tried with ProgTV, Perfect Player and Kodi (FTMC), no success.
            Hello!
            Just tried with SmartIPTV and nothing. =/
