Wechip V5 TV Box - Amlogic S905X 2GB RAM + 16GB ROM Android 6.0 2.4GHz + 5GHz WiFi Bluetooth 4.0
    Click image for larger version  Name:	wc1.png Views:	1 Size:	172.1 KB ID:	677147
    ● Android 6.0 improves user experience compared with other versions of TV boxes. People can install or uninstall software, games and application programs easily.
    ● Support mouse and keyboard via USB. Support 2.4GHz wireless mouse and keyboard via 2.4GHz USB dongle.
    ● Support both H.265 and VP9 decoding, which is the absolute mainstream decoding formats in the global.
    ● 2.4G + 5.8G offer a more stable signal for you to enjoy higher quality video experience.
    ● Support 5.1 surround sound output, capture your ears with actual listening feelings.
    ● HDMI 2.0 is a faster way to send video and audio output to your TV.
    Gearbest
    Today can have a look at the Wechip V5 TV Box - Amlogic S905X 2GB RAM + 16GB ROM Android 6.0 2.4GHz + 5GHz WiFi Bluetooth 4.0
    Amlogic S905X, with 2/16GB Ram
    Simple Plain Box
    What's in the box
    Underside
    Front then Ports
    TopView
    Underneath PCB
    View or parts top side
    Top, Base and Wifi Antenna,
    Light Show
    More on this Later
      Well more of the same with this Rom at Present.
      Google Problems, is about all we have, and weather not connecting,
      Just annoying things that don't make the OBE enjoyable but as we know it happens...
      Running Android 6 this time, Root and Taskbars etc....
      Found another Rom on there website about to flash to see if it helps as it has no indication to the date of the .img file, I am going to guess its the same at the present.
      Flashed Rom even older than what was installed way back December 2016...and same google issues....
      Next we tried a Different Launcher to see if that will do good or bad
      Well it did Good most seems to be working OK.
      Only thing we have lost is Control of the LED on the Box it stays Blue and can't be switched off or cycle colours but i can live with that..
      Some apps not running in Full landscape, build prop fix for that. Enter on Keyboard end the generic.kl
      a few minor fixes and all seems in order...
      Testing to come...
        Moving along with a bit of Normality
        Temps looking OK, in the Zone.
        UI launcher Piece of Junk caused more problems than anything this launcher.
        System Info think it was on qb005 before I flashed.
        Ram and Storage Truth
        DRM Info
        CPU-Z
        GeekBench CPU
        Geekbench COMPUTE
        Monitoring
        WiFi Ok
        A1 SD-Bench.
        Boxes working ok, hardware appears same.
        Just needs to get their software sorted and it may be a better unit.
        Thanks Gearbest
          Ok after testing a lot of 905x firmware looks like there a few nice options for this Donkey device and works well. I'll pull the remote file outa stock then post the working ones.
          Super Celeron
          http://freaktab.com/forum/tv-player-...atv-android-tv
          Magendanz
          http://freaktab.com/forum/tv-player-...ano-nexus-roms
          2 start off those both work everything work even power on button because it's hardwired.
          only bricked the donkey once lol.... Have 7 also working but still checking I'll keep posting as they work. That's a start anyways...
          unpacking Rom for remote I'll post that once done. Everything works just didn't check sd card as none where I am am.
          WECHIP SEND FREAKTAB DEV TEAM A XMASS PRESENT THEY SAVED YOUR DONKEY DEVICE....
            replace remote config with this one in system /ect now device no longer donkey it back to race horse style.
            donate to freaktab or devs if it makes your box work.
              So after week of testing looks like lots work on it best is both first two I posted. It actually Runs faster then the box designed for it. Stock firmware is useless.
