SD card / .zip file method will not work
Burn Card Maker method sd card finally turns on display - upgrade stops after 30 seconds and will not continue.
I can run TRWP on SD card - it shows 0MB for /data, /system, etc.
Changing file system to any type fails,
Trying to sideload fails
Trying to recover a backup fails
Trying to install any .zip file fails.
Seems like a partition issue. Does anyone have any tips or is it completely bricked?
