before i start, I used the search function and read TONS of threads, and still i don't understand, and really in the need of help.
I just got my MK809III from **** (http://www.****.com/itm/MK809-III-Ro...vip=true&rt=nc)
1.WiFi is REALLY slow (when it even connects), i am about 3-5 meters from the Access Point (it's in another room).
Trying to download an app from the Play Store or even opening it is a PAIN, it just takes forever.
Running SpeedTest i get Really low scores, that do not resemble my home connection.
I get "Good" signal (2 out of 3 lines), and menu settings says "54Mbps".
I tried to use my Galaxy S3 as an Access Point and put it RIGHT on the MK809III, WiFi signal was "exellent", and it worked, but still REALLY slow.
Just transfering an app inside the LAN from my PC was MAX 17\kbps (most of the time alot slower).
Also tried Bluetooth internet Tethering, opened it on my device, and on the MK i did "use this device's internet"... nothing happened.
Is there anything to do?
2. XBMC works bad, playing video, ANY video, doesn't matter what quality, stutters like crazy, impossible to watch.
As far as i know i'm on 'stock' rom 4.2.2... (i don't think its rooted)
when i get home i will post the exact build number and kernel version.
I don't understand what roms\kernels are for this device (im not sure what exactly i even have)
Please any advice will really help me, i feel like i just threw a lot of money to the garbage
If needed i will open the device and tell any details you need.
Thanks a lot in advance!
EDIT:
model number: rk31sdk
Android Version: 4.2.2
Kernel Version: 3.0.36+ hotack@adminroot-X9DRL-3F-iF #49
thu Jun 20 14:11:45 CST 2013
Build number: rk31sdk-eng 4.2.2 JDQ39 eng.hotack.20130620 test-keys
Vendor software version: RK3188_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130514
ADDED Pictures on Post #4 & #5.
