H96 Pro+ Launchers
    H96 Pro+ Launchers
    I have gone through a few Stock firmware Launchers and tested them with the H96 Pro+
    as tbh most of these boxes are running the same base firmware with minimal changes to the launcher and a few apps
    Someone might find it useful so im posting it here
    I will update it once in a while
    all of the launcher are here
    Some edited stock Launchers with thanks from Krypton
    also look at his edited Lighthome Launcher
    AmlLauncher_canzone_7.1(H96 PRO+ 26-08-17-K1)
    Netflix Replaced with kodi
    Youtube TV 1.xx.xx
    AmlLauncher_canzone_7.1(H96 PRO+ 26-08-17-K4)
    Youtube TV 2.xxx.xx
    Need to be manually placed in /sytem/app with required permisions & delete AmlLauncher_canzone_7.1.apk then reboot
    AmlLauncher_canzone_7.1(H96 PRO+ 26-08-17 + H96 PRO+ 10-10-17) com.canzone.amllauncher
    AmlLauncher_canzone(H96 Pro+ 28-12-16) com.canzone.amllauncher
    AmlLauncher_canzone_russian_7.1(23-09-17) com.canzone.amllauncher
    Installs Fine over H96 Pro+ Launcher,Updates Back Fine
    AmlLauncher_lihai_7.1(Quintaix Q912 27-06-17) com.canzone.amllauncher (Needs Cleaner Addon if you want the Cleaner Shortcut to work)
    Installs Fine over H96 Pro+ Launcher but
    Needs to be deleted from /data/app manually cant update over it back to H96 Pro+
    AmlLauncher_canzone_guodi_7.1_urock(04-05-17) com.canzone.amllauncher
    The Youtube Shortcut is for the standard PlayStore Youtube App
    AmlLauncher_canzone_guodi_7.1(S912 10-10-17 With Cleaner) com.canzone.amllauncher
    AmlLauncher_canzone_guodi_7.1(S912 10-10-17 Without Cleaner) com.canzone.amllauncher
    MINIX_METRO(NEO U9-H FW006) com.xiaozhenhe.minix
    Doesnt Hide Top Bar
    Can be installed alongside Stock Launcher
    BeeUI(MINI M8S PRO 13-07-17) (com.netxeon.beeui)
    AmlLauncher_rkm_7.1(MK22PLUS 01-09-17) com.canzone.amllauncher
    Tested On
    Thank you very much , been looking for this
      with regards to the pm
      each version says if it needs special instructions to install
      for example the english launcher with kodi instead of netflix is signed with a different key
      so you have to replace the launcher in /system/app set permissions then reboot
      the rest can just be installed over the default launcher as an update
        what permission do you advice ? rwx r- r-?
          Anyone tryed the ugoos test version yet?
            same as the old apk
            -rw-r--r--
              same as the old apk
              -rw-r--r--
              works great now , thank you
                The ugoos launcher is on the play store and works fine
                its using the same base code as the new tanix and vorke launchers
                good that they have put it on the play store though
                • scooter2014
                  scooter2014 commented
                  Editing a comment
                  No was asking about the new Beta on thier blog..
                Yer just tried it it crashes like nova does
                  Used Just Tv launcher in playstore not to bad. Can custimize ect.
                    Hi all am quite new to these boxes and I would like to install the above launcher with Kodi on it to get rid of Netflix as I don't use it. I am unsure how to go about doing this is there a walk through or anything that I could follow to do it like getting access to where I need to be in the file structure and how to set the required attributes for the file? Software reports my H96pro+ box to be ROOTED but thats as much as I know right now. I have downloaded the file from the download site already and I need to follow this instruction "AmlLauncher_canzone(H96 Pro+ 28-12-16)
                    Need to be manually placed in /sytem/app with required permisions & delete AmlLauncher_canzone_7.1.apk then reboot"
                    TIA Satmaniac
                      Shonk what cleaner does
                      AmlLauncher_canzone(H96 Pro+ 28-12-16) use?
                        built in
                        though it uses the old stock browser instead of chrome for the browser link (its on the mega link)
                          Can these launchers provided here be installed on any other android box? The H96 pro ones for example are those only for the H96 pro box? I'm not getting them to work on my T95V K pro? am i installing them wrong?
                            built in
                            I have this working now too but the large Browser button does nothing, I see a rar archive on the mega with a bowser apk file in it but no instruction what have I got to do to get the borwser button working again please? On mt original launcher this button launched Chrome for me. Cheers Satty
