Restarting H96 Pro +
Originally posted by BlackBriar56 View PostOne suspect is the charging cable. try to plug in a different one with the same voltage and see if it still shuts down.Last edited by dragon138; 10-16-2017, 21:03.
Esas cajas deben de ponerse el fw https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!Bqo1FDoQ ya que es un fw especial para cajas con chip diferente a los demas .
si quieren poner otro fw deben de saber que no se van a reiniciar y que si lo quieren apagar tienen que poner en las opciones reiniciar en ved de apagar porque de lo contrario cuando se apague os saldra una luz rojo y no lo podreis encender solo sera desenchufandolo de red electrica
Originally posted by Oops View PostYou can try this one too. Rom provided by gearbest.
https://drive.google.com/file/d/0Bxr...kwNFRweW8/view
The remote has stopped working and that was the only way to power on. My airmouse will only power the unit OFF! I did try to programme the air mouse with the IR signal of the H96 remote's power button before it died but it didn't seem to store it. Is there an alternative remote?
The box also turns off when I switch inputs on my AV amp so I have to unplug the box to restart. Hopefully turning HDMI control on the amp off will stop this so I can just leave the box on permanently. Not ideal but as I need to amp to automatically switch my TV inputs but what are the alternatives? Programming the airmouse to turn the box on would be perfect.
@johnfirewall,
To prevent box from going to sleep mode(red light) or powering off(?), disable CEC in Android settings.
Your power on by remote/ off by air mouse is common with updated firmwares.
There might be a TWRP fix/flash on these forums or maybe 4PDA(?). I might be mistaken...been a while.
That's already off, so I also turned off the HDMI Control setting on my amp, but yes in theory it should not accept that message from the amp if that setting is turned off.
I would quite like to upgrade the FW as I get occasional WiFi issues too among other things but doesn't sound like updates fix anything going by posts in here and I've only ever done OTA updates on my devices in the last few years.
For one of the more expensive boxes this is terrible.
There are currently 2392 users online. 5 members and 2387 guests.
