Alfawise H96 Pro+ my third curious box
    I already reported in the rom-section of superceleron (SCV7A) about my curious 3. box which i got recently.
    I don´t want to occupy more that section with this, for this reason i opened a new thread here. But also perhaps to help others with same issues.
    Details you can read here: #1357
    I would like to have your opinions about this strange behaviour of this box and get perhaps some answers.
    The first 2 boxes are running so smooth with the SC roms, but this 3. box did not like it, don´t know why. This box was cheaper than the others, sure have some other hardware, but i don´t want to open it once more. I had already opened it, but did not note the devices...
    Now, with the help of valencia7514 and this link http://www.hcygood.com/news/html/?462.html i could recuperate this box, which i had already prepaired to send back to China.
    this is the rom i installed
    aml_7.1_s912_q9377-H96PROPLUS_KDMC_mac-20170826.img
    It was the only rom which i could install, before i tried other older stock roms, also all roms (incl. TVroms) from SC.
    UT WHAT IS THE CONFLICT BETWEEN THE HARDWARE AND THIS KIND OF ROMS
    Now it is running with TVLauncher, very clear, simple and effective Launcher.
    I don�t want to occupy more that section with this, for this reason i opened a new thread here. But also perhaps to help others with same issues.
    The first 2 boxes are running so smooth with the SC roms, but this 3. box did not like it, don�t know why. This box was cheaper than the others, sure have some other hardware, but i don�t want to open it once more. I had already opened it, but did not note the devices...
    I know I had the same to later found out that the box is a old h96 pro banded has pro plus thats way so many headaches, apart from that I was able to run scv7 but it hangs a lot and its running very slow
    Enviado do meu GT-N8000 através de Tapatalk
      as you did the process put the steps so that we already know first installed the img? and then the superceleron android tv? with what program is .zip the android tv?
        not clear for me, what you want finally know....???
        in my first posting i informed, where i started my report about the box-problems i had. (Details you can read here: #1357)
