Vorke Z6 Review
    Vorke Z6 Review
    VORKE Z6 KODI 17.4 Android 7.1.2 Amlogic S912 4K TV BOX 3GB DDR4 32GB eMMC5.0 AC WIFI 1000M LAN Bluetooth 4.1
    Hi Guys,In this review i will be looking at the new Vorke Z6 form Geekbuying
    Highlights (From webpage)
    Vorke Z6 - The Most Powerful Android TV Box
    It turns out, this part of the question is actually very simple. Vorke Z6 is one of the most powerfull smart Android Nougat TV boxes powered by the Amlogic S912 SoC .Yes you heard right, it is the best box available at this moment.
    When it coems to memory, Vorke Z6 has 3 GB of RAM combined with a 32GB of storage space which of course you can upgrade using the microSD card. As you can see, without exaggeration, it has strong hardware for its price tag.
    Of course, you may try many different things from playing games, watching 4K movies, to surfing the Internet and more importantly, everything is expected to work precisely as it should. In a nutshell, Vorke Z6 should be the go-to choice if you’re someone who`s new to streaming devices and TV boxes, or a professional who wants an option to install whatever apps that are preferred.
    Video Playback with Kodi 17.4
    Normally, Kodi is the key to every media player, Z6 is no exception.It comes with the newest Kodi 17.4 which will worklike a charm. In other words, it will work without any lags, when watching movies, TV shows,playing games, or whatever of your choice.
    AC WiFi, Gigatbit Ethernet and Bluetooth 4.1 Connectivity
    We noticed that cheaper models does not have some connectivity functions like Bluetooth which is very important for several reasons, especially for wireless keyboards, mouses, and most important gamepads. But don’t worry, Vorke Z6 has all connectivity functions including Bluetooth v4.1, besides the Wi-Fi 2.4GHZ/5.8GHZ 802.11a/b/g/n /ac, and 100M/1000M Ethernet.
    The Vorke Z6 arrived to the UK in just under 2 weeks via snail mail so not bad postage time at all.
    As you can see in the unboxing video the Z6 comes in a plain brown box and has everything you need to get started.
    This is a great little box and has surprised me on how well it works out of the box
    On the front there is the LED clock when the Z6 is powered on.
    On the rear you will find the Power port,HDMI port,Ethernet port,2x USB2,SPDIF & the recovery button
    On the left hand side you will find the SD Card slot.
    Both sides of the z6 have vents for cooling
    Home Screen
    The Vorke z6 has its own launcher
    App Draw
    Quick facts
    3GB RAM & 32GB ROM
    Boot time is around 35 seconds from pressing the button
    The Z6 TV Box has the well known Amlogic S912 processor
    Bluetooth v4.1, Wi-Fi 2.4GHZ/5.8GHZ 802.11a/b/g/n /ac, and 100M/1000M Ethernet.
    H.265 HEVC MP-10@L5.1 up to 4Kx2K@60fps
    H.264 AVC HP@L5.1 up to 4Kx2K@30fps
    H.264 MVC up to 1080P @60fps
    KODI 17.4
    Android 7.1 Lollipop out of the box
    Google play store installed
    Rooted
    Some Tech Stuff
    DRM info
    The Amlogic S912 are the right box's to buy right now as the Amlogic is by far the best IMO
    Bluetooth 4.1
    Kodi
    The Z6 comes with Kodi 17.4 preinstalled with a addons file you can install if needed.The speed of kodi is Nice & fast 4 seconds to load from the app screen,Iv been streaming 1080p & 4k from the web with great results no video stuttering that iv noticed.
    Games
    Iv tested games like Asphalt 8 & beach buggy blitz with graphics set to high they played perfect.
    All games tested was with the tronsmart Mars G01 Game pad
    Misc
    Logitech c270 camera works fine
    External powered 1T HD works fine
    Tronsmart Mars G01 game pad works
    32GB sd card works fine
    The Z6 gets warm but not hot as there are some venterlation holes on both sides,Iv had it running 24/7 now for the past week streaming from my ip cam & all is working well no lock ups reboots ETC.
    Internal Photos
    As you can see in the next photo there is a heat sink its only a tiny one but with that said im not getting any over heating.
    vorke z6 firmaware (20170906)
    http://vorke.mediafire.com/file/o64n...-PC-rooted.zip
    Vorke Z6 Video Review
    1 x TV box
    1 x IR remote
    1 x HDMI cable
    1 x Power adapter
    1 x User manual
    Unboxing video
