A Wetek BT Gamepad...as my game skills are hopeless I am told this will fix all.
Just like there are Unicorns and Moon is made of cheese..
Anyway a good looking device with all the buttons you need to tromp and stomp
Analogue stick to run and hide or steer into a brick wall, to easy.
Upper and lower shoulder buttons, and Illuminated buttons incase you forget what button to push.
A good solid device to grip, good to hold.
USB Port in in front to Charge Battery or connect to your PC, and a reset button underneath
WeTek Gamepad is a gaming controller compatible with Windows via USB, and Android system via BT.
Feature precise asymmetric 360 degree sticks, and is fully rechargeable
WeTeK
