Beelink GS1 6K TV Box - Allwinner H6 Android 7.1 BT4.1 1000M LAN USB 3.0 Media Player 2GB RAM + 16GB ROM
    OK, I have not seen that on any of the playback settings, 1440 but no HDR, still looks excellent
    DDR3..by PCB markings.
      Further Fiddling, found the TV can to HDR,
      Some adjustments made but still no luck at this stage. more to come.
        Hi Trebor,can you test wi fi for me,test the signal reception strainght,this is wery important for me,I cant connect with LAN,only wi fi. Thanks...
          OTA Update today
          1. solving update error from differential packet,.
          2. solving no response by clicking "enable startup wizard" in setting.
          3. solving system crash if HDD over 2TB connected.
          4. Adding updating by TF card(last version support updating by U-disk).
          5. solving music player pop up when select video files in file manager.
          6. optimizing video play.
          7. fixing RCU back button no repsonse when in Kodi.
          8. updating wifi driver to solve wifi reconnection problem after drop.
          First try could not find file and dropped to recovery.
          Second try found file all good.
            Originally posted by mitchell4you View Post
            The vid above 9:23 says beelink gs1 is using ddr3
            This is how to check for youtube hdr:
            Further to HDR and finding how it all comes together sort of
            TV is in HDR mode
            Box is in HDR mode, and TV can indicate what the input/display is
            Cannot as yet YT to display as shown with HDR
            Using TV on YT also does fails to indicate, as yet
              Ok.
              • trebor
                trebor commented
                Editing a comment
                Over the Air...first one dropped to recovery second try all good
              #22
              Just a headsup...
              I checked.. about HDR and youtube inside XDA found a nice app called IYTBT
              its youtube but modded:
              *dark skin
              *block ads
              under settings:
              *force vp9
              *bypass hdcp sceen limit
              *max res 2160p
              I tested this on a box running cm12.1 without google apps.. Installed iytbr and it worked
              ** no popups stating i need google-market etc
              comes in 3 versions..non-rooted and rooted versions
              himedia uses a kodi wrapper...aka external player for HDR vids
              that makes me wonder...does the internal player maybe... play youtube HDR vids?
              anyway.. thats my last rant about hdr
                Thanks yes the Complications of YT and what it can and cant do, all down to the DRM i guess
                Yep the Internal player does VP9 and most other types I throw at it.
                The wrapper the savior for those files that don't..
                All good
                  Mxplayer and beelink gs1 topic
                  looks like beelink developers forgot a profile?
                  • trebor
                    trebor commented
                    Editing a comment
                    Will bother Some,for sure, lets see if they can fix
                    Good find
                  #25
                  FIRMWARE updated to the latest version, settings restored to factory settings - the MIRACAST function does not work on any of my devices. At home I use SAMSUNG S4 ACTIVE (official ROM ANDROID 5.X), SAMSUNG S4 ACTIVE (LineageOS 15 - OREO) and HUWAEI HONOR (officiall Android 6.0). After starting the application, miracast finds (not always devices) links, then the screen the blinks are getting black as the image transfer was supposed to start and re-start trying to connect ...
                  This is the basic function for which you purchased the device, and it does not work, please help and advice.
                    Hoped for better performance since it is based on the same hardware as Zidoo H6.
                    Almost impossible 4K playback, no HD Audio and memory management issues. Beelink should provide a better fw.
                    1080p Netflix works fine though.
                      Update:
                      http://freaktab.com/forum/tv-player-...16g#post701349
                        Update soon if not already,
                        GS1-
                        Build Number 105N0
                        1, Optimizing mouse jittering after zoom out some screens.
                        2, Optimizing the breakdown of input method in some times.
                        3, Updating shorcut app.
                          Good news! The 104N0 had a lot of problems.
                            Ota Update
