OUKITEL K5000 Full specs released, Perfect Combination of “Big” and “Small”
    Click image for larger version  Name:	OUKITEL K5000.jpg Views:	1 Size:	99.2 KB ID:	679525
    Due to the continuous evolution of full screen technology, 18:9 full displayed smartphones is becoming more and more exciting in view and real friendly to hold in hand. OUKITEL released the MIX 2 and C8 to satisfy needs for the high-end and entry level choices. In the “K”series that OUKITEL have been proud of, OUKITEL is releasing the K5000 which perfectly combines “Big” and “Small”.
    Video: OUKITEL K5000 Full Display Design:
    OUKITEL K5000 is Samsung S8 style full display. It combines big 5.7 inch large display and 5000mAh big battery to the slim and thin body that can be hold in one hand.
    Narrower bezels, virtual keys, and concealed proximity sensor, OUKITEL insert the 5.7 inch big display into the body that is smaller than traditional 5.5 inch body. Let's see the full specs.
    Processor: MediaTek MT6750T octa-core Cortex A53 1.5GHz , ARM Mali-T860 MP2
    OS: Android 7.0 Nougat
    Display:
    Size: 5.7 inch HD+, 720*1440 resolution
    Touch: 5 points multi-touch
    Color: Brilliant Blue, Jet Black, Champagne gold
    Cameras:
    Primary: Sony IMX135 sensor, 13.0MP, 16MP interpolated, true-tone LED flash light
    Secondary: Samsung 3P3 16.0MP, 21MP interpolated, flash light support
    Memory: 4GB RAM+64GB ROM, 128GB expandable
    Network:
    GSM: 850/900/1800/1900MHz;
    WCDMA: 900/2100MHz;
    4G FDD: B1/B3/B7/B8/B20
    SIM card type: 1 nano SIM+1 SD card;2 nano SIM
    Connectivity:
    USB Port: Type-C port
    Ear jack: Type-C port
    WLAN: Support,802.11 a/b/g/n/,Hotspot
    Bluetooth: V4.0
    Sensors:
    Frontfingerprint sensor/ Gravity sensor/ proximity sensor/ Light sensor/ gyroscope sensor/ geomagnetic sensor
    OTG: Yes
    OTA: support
    FM Radio: support
    Dimensions: 152.1*73.1*10.8mm
    Battery: 5000mAh, 9V/2A charger
    Large usable display, large battery, large flash memory, great camera, fashionable double curved design, OUKITEL K5000 defines a new trend for large battery smartphones. Not thick and heavy body, not low-level configurations, not just-so-so cameras, but a finely designed fondle admiringly high-end art. K5000 will get 3 colors: Brilliant blue,Jet black and Champagne gold. It will be sold at $159.99 for retail, but OUKITEL will offer discount for pre-orders. K5000 plans to start presale from October 23rd. Detailed stores and discounts will be announced on OUKITEL official website www.oukitel.com
    Click image for larger version  Name:	image_27870.jpg Views:	1 Size:	134.6 KB ID:	679524
    http://oukitel.com/
