M8S PLUS II 2GB / 16GB DDR3 firmware request
    Hello,
    I have a box called M8S PLUS II and the latest firmware which I found is for Android 6.0
    https://www.entertainmentbox.com/lat...rshmallow-6-0/
    I tried several H96 Pro Plus firmwares and they do not seem to work. Upgrade fails or they boot loop. For example I tried : aml_7.1_s912_q9377-S912_KDMC_mac-20171010.img and Ebox_H96_Pro_+.7.1.2.img and M8S_PRO-V0619_TVStock-20171001.img
    Now tried aml_7.1_s912_q8723bs-H96PRO-dongle_KDMC_mac-20170810.img also but it does not boot with it either.
    I am attaching images from inside the unit. Can you tell if there is a compatible Android 7.x firmware for this unit?
    Thanks!
    You may only view thumbnails in this gallery. This gallery has 7 photos.
