5000mAh battery and 18:9 Display, OUKITEL K5000 presale starts from $149.99
Name:	OUKITEL K5000 presale.jpg
    According to OUKITEL Official, OUKITEL K5000 will start presale from October 24th. As a combination of 5.7inch 18:9 large screen and slim and thin body, a century joint of Samsung camera and Sony camera, an evolution of elegance by dual curved mellow design, K5000 shows how it should be as a full display smartphone. During presale, K5000 will only sell at $149.99 out of the original price of $169.99.
    Before making decision to buy this K5000, there are some detailed features you should know. As we collect, the following 8 point makes OUKITEL K5000 a worth buying mobile.
    First, 5.7 inch 18:9 large display. K5000 gets a 5.7 inch display, but its body is smaller than traditional 5.5 inch smartphones. It’s hard to find a smartphone with bigger display but smaller body than K5000. Slimmer body allows you to hold it in one hand but views more.
    Second, 5.7 inch HD+ display with 720x1440 resolution. With the same photo, HD+ display shows brighter and more colorful colors than HD screen. It also saves much power than FHD displays.
    Third, 21MP Samsung front camera and 16MP Sony IMX135 rear camera. The first smartphone that joins Samsung camera and Sony camera. Absolutely taking great photos.
    Fourth, 5000mAh SCUD high-density battery. Battery percentage decides whether you takes a power bank every day or not. With K5000, no worry.
    Fifth, 4GB RAM+64GB ROM with 128GB expandable memory. By 4GB RAM and powerful MT6750T octa-core chipset, you can run more than 50 apps fluently at same time. Store as you like, play as you like.
    Sixth, 9V/2A quick charge and Type-C USB port. With a quick charge charger, you can save much charging time.
    Seventh, Press fingerprint unlock. K5000 lays the quick press fingerprint sensor on the back. Unlock in black screen quickly.
    Eighth, Dual curved fashionable design. The phone you hold should match your hand. K5000 has got 2.5D curved design, CNC crafting frame, and 3D curved glossy design. Simple lines in each angle all shows its elegance and beauty.
    See the below video about OUKITEL K5000 first hands on:
    OUKITEL K5000 has got 3 colors, brilliant blue, jet black and champagne gold. During presale from October 24th-October 31st, K5000 is sold at only $149.99. Meanwhile, to celebrate the presale of K5000, OUKITEL is holding several giveaways on OUKITEL Official facebook page, twitter and VK group. To know details about K5000 and presale details, click here: http://www.oukitel.com/products/k/oukitel-k5000-78.html
Name:	OUKITEL K5000 colors.jpg
    http://oukitel.com/
