I just purchase Beelink SEA I 32G i field to install supersu and i get this error "couldn't be installed. Free up some space and try again" when i run the apk file and from google play i have this error -506
Supersu can not be installed
Hello every one,
I just purchase Beelink SEA I 32G i field to install supersu and i get this error "couldn't be installed. Free up some space and try again" when i run the apk file and from google play i have this error -506Last edited by divide; 24 October 2017, 13:56.Tags: None
Originally posted by divide View PostHello every one,
I just purchase Beelink SEA I 32G i field to install supersu and i get this error "couldn't be installed. Free up some space and try again" when i run the apk file and from google play i have this error -506and i don´t know how to boot it again , i´m able to acces to Android Recovery pressing the reset button and plug it back to power but i cannot pass beyond "please wait" screen , i don´t know what to do
, seek for more information before succesfully install super su and reboot, don't brick yours
Thank you both for your reply
Originally posted by mitchell4you View PostHmm.. ( on most Android devices )
try :
/settings/storage/click on cache ( then a pop-up emty cache yes/no )
Originally posted by Daviila View Post
I just bricked my "two times used" Gt1 ultimate by installing Super Su...and i don´t know how to boot it again , i´m able to acces to Android Recovery pressing the reset button and plug it back to power but i cannot pass beyond "please wait" screen , i don´t know what to do
https://www.zidoo.tv/Support/guide/g...McQ%3D%3D.html
i believe this topic have same issue you face maybe it will help
https://forum.xda-developers.com/201...persu-t3507127
Originally posted by divide View PostThank you both for your reply
I have delete the caches and try to use lucky patcher for odex files nothing change same error , while i search superceleron said root/su apps are blocked by the sdk and there is no one talk about bypassing the blocking i will try to install supersu through recovery mode after i prepare TWRP
sorry to hear that, i'm thinking that i will re-image the box with zidoo X9S rom its have same hardware specs and supporting supersu
i think no more "super Su" installing attempts for me.. i'm so happy.... and so scarede to try it again.
My Tv Box: Beelink Gt1 Ultimate 3GbDDR4 32GB S/N AX12
There are currently 2725 users online. 1 members and 2724 guests.
