EMMC Initialisation
    EMMC Initialisation
    For reference i am checking emmc + sd card initialisation by various firmwares
    and will post here now and then
    you can check this yourself with dmesg via sshdroid from the play store
    it would help if other people do the same whilst stating theyr nand chip and firmware
    you need to look through dmesg fully as it does a tuning stage on the nand later in the boot process
    which the h96 firmware isnt doing atm on the emmc
    the end goal is to find the best firmware and to try and shame the box makers into fixing this
    MY H96 PRO+ Nand 32GB Toshiba 19nm THGBMBG8D4KBAIR 170821AE EMMC HS400 V5.0 Read 270MB Write 90MB
    Spec'd Speeds
    EMMC = HS400 MMC emmc: clock 200000000, 8-bit-bus-width DDR
    SD Card = SDR104 SD sdio: clock 200000000, 4-bit-bus-width SDR
    Libreelec 8.1.10 2017-10-08
    emmc: try set sd/emmc to DDR mode
    emmc: new HS400 MMC card at address 0001
    emmc: clock 100000000, 8-bit-bus-width (running 1/2 speed hdparm -t = 135mb)
    sdio: new ultra high speed SDR104 SDIO card at address 0001
    sdio: clock 200000000, 4-bit-bus-width (correct)
    aml_7.1.2_s912_q9377-H96PROPLUS_KDMC_mac-20171010
    emmc: new DDR MMC card at address 0001
    emmc: clock 50000000, 8-bit-bus-width (running 1/4 speed hdparm -t = 67mb)
