i92 PRO Android TV Box S912 - 2/16GB ROM Dual; WiFi Ethernet 1000M BT4
    Description:
    Comes with octa-core Amlogic S912 CPU, this i92 PRO Android TV box will make you have endless entertainment every day of the week.
    Supports BT 4.0 and 2.4 / 5.8GHz WiFi, it is a perfect device for providing 4K ultimate HD video, you will see the movies with more vivid color, creates your own home theater easily.
    Have this Android TV box, you will have a wonderful and enjoyable time with your family, friends.
    It is more than a TV box, it will make your home smarter and happier.
    Features at a glance:
    - Supports multiple connections such as BT4.0, Ethernet 100 / 1000M, 2.4 / 5.8GHz WiFi, USB flash drive, TF card (TF card is not included)
    - Android 6.0 operation system is one of the most popular operating systems around and will bring an unparallel level of controlling to your TV
    - Equipped with 2.0GHz Amlogic S912 CPU, and Mali-T820MP3 GPU
    - With the HDMI 2.0 data output, supports H.265
    - Supports Miracast, Airplay, DLNA
    Gearbest
    Lets have a close look today at the i92 PRO Android TV Box S912 - 2/16GB ROM Dual; WiFi Ethernet 1000M BT4.
    - Supports multiple connections such as BT4.0, Ethernet 100 / 1000M, 2.4 / 5.8GHz WiFi, USB flash drive, TF card.
    The Box
    What's in the Box
    Ports etc.
    Underside reset and upgrade button
    Remove the Lid
    Out with the PCB
    Closer look Underside two buttons
    Closer look Topside
    WiFi Chip
    Good to see, easy to fit a fan if needed
    The light show
    Gearbest
      Running Android 6 at present, maybe a A7 update about or q201_9337 should do the job i feel
      The setup of Google accounts and downloaded apps etc all good.
      Wifi and Ethernet speeds good here.
      Has Root, no Upper or Lower Bars.
      Clock display a bit bright
      Temps not too bad at this stage.
      Noted a couple of apps don't run full screen, and not 100% keyboard friendly, Enter key etc, minor fix,
      Appears to work as it should and a neat looking unit
      Let's have a look see and what it has to offer.
      Intro:
      UI, simple and clean
      System Info
      DRM L3
      Ram and Storage Truth
      CPU-Z 4 frames
      Interesting Player
      AIDA64 7 frames
      A1 SD
      Thanks to Gearbest
        I am about to buy this box for 30EUR brandnew, anyone tried ATV rom?
