i98 PRO Android TV Box S905X - 2/16GB WiFi 2.4Ghz Fat Lan BT4.
    Description:
    With the i98 PRO Android TV box at your disposal, you don't have to worry about that the boredom will enter your household. This updated i98 PRO Android TV box will provide you with smooth experience to watch the video or play games.
    Supports BT 4.0 and 2.4GHz WiFi, it is a perfect device for providing 4K ultimate HD video, you will see the movies with more vivid color, creates your own home theater easily.
    Have this Android TV box, you will have a wonderful and enjoyable time with your family, friends. It is more than a TV box, it will make your home smarter and happier.
    Features at a glance:
    - Supports multiple connections such as BT4.0, Ethernet 10 / 100M, 2.4GHz WiFi, USB flash drive, SD card (SD card is not included)
    - Android 6.0 operation system is one of the most popular operating systems around and will bring an unparallel level of controlling to your TV
    - Equipped with 2.0GHz Amlogic S905X CPU, and 5-core Mali-450 GPU
    - With the HDMI 2.0 data output, supports H.265
    - Supports Miracast, Airplay, DLNA
    Gearbest
    Thanks to Gearbest we can have a close took today at the i98 PRO Android TV Box S905X - 2/16GB WiFi 2.4Ghz Fast Lan BT4.
    Model: i98 PRO
    Type: TV Box
    System: Android 7.1
    CPU: Amlogic S905X, Cortex A53
    Core: 2.0GHz
    GPU: Mali-450
    RAM: 2G
    RAM Type: DDR3
    ROM: 16G
    Max. Extended Capacity: SD card up to 32GB (not included)
    Decoder Format: H.265,HD AVC/VC-1,HD MPEG1/2/4,RealVideo8/9/10,RM/RMVB,Xvid/DivX3/4/5/6
    Video format: AVI,AVS,DAT,FLV,ISO,MKV,MOV,MPEG,MPG,RM,RMVB,TS,VO B
    Audio format: AAC,AC3,APE,DDP,DTS,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Bluetooth: Bluetooth 4.0
    Power Supply: Charge Adapter
    Interface: AV, DC Power Port, Ethernet, HDMI, Optical, SD Card Slot, USB2.0
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: 3D Video,Airplay, DLNA, Miracast
    RJ45 Port Speed: 10 / 100M
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Power Input Vol: 5V
    Remote Controller Battery: 2 x AAA battery (not included)
    Product weight: 0.2650 kg
    Package weight: 0.3600 kg
    Product size (L x W x H): 10.00 x 10.00 x 2.00 cm / 3.94 x 3.94 x 0.79 inches
    Package size (L x W x H): 18.00 x 11.00 x 5.50 cm / 7.09 x 4.33 x 2.17 inches
    Package Contents: 1 x TV Box, 1 x Remote Controller, 1 x HDMI Cable, 1 x Charger Adapter, 1 x English User Manual
    The Box
    Contents
    Ports, no display in front just the IR window
    Pop the Top, another good device to fit a fan.
    Remove PCB, 3 Buttons could be fun
    Light show device, does a 3 colour cycle
      Not to bad, all seems in fairly good order, considering the amount of time the S905X has been around you would hope
      We have Root but no Upper or Lower Bars
      Good setup all good no funny business Ethernet only tested as antenna broke,
      A couple of testers don't run full screen..
      Lets have a lool
      UI and Installed Apps
      System Information
      Droid Settings
      DRM Information
      CPU-Z 3 frames
      Root
      Ethernet
      Ram and Storage Truth
      Geekbench CPU More >
      http://browser.geekbench.com/v4/cpu/5525105
      Geekbench Compute
      AIDA64 6 Frames
      A1 SD
        Hi Robert, i have this tv box and i would like to flash a custom rom (android tv 7.1) superceleron or magendanz for M8SII would work or any other recommendation ?
        Thanks in advance.
        • trebor
          trebor commented
          Editing a comment
          Some may, WiFi / BT and remote may be issue.
          Not sure of any specific Custom rom that would.
        Thanks for your reply, have you ever try to put it on recovery mode and have it detected in the usb burning tool because on my side it doesn't work (toothpick in reset hole + usb otg port). As there are 3 buttons under the motherboard (1 reset and 2 upgrade) there might be a special way to do it. Would you mind trying on your side and let me know (not flashing just have it detected by the burning tool) ?
        Thanks for your help.
          For those interested had it working with usb tool (plug usb to pc, open tool, load rom, press start and then plug usb pressing upgrade button on back of tv box) xanny 3.0 rom working, wifi ok, no bluetooth..(if someone can make work bluetooth please let me know)
            firmware i98 pro
              can help firmware i98 pro
                Hi, I have this TV box but it is based on S905W not S905X. Got a number of problem with it.
                1)Wifi speed less than 20Mbps, normally less than 10Mbps, Lan connection also less than 30Mbps, normally only around 20Mbps. Lan speed should get at least 90Mbps since my bandband is 1Gbps and spec states 100mbps. I have a X96mini can get 92Mbps under the same condition. 2) Cannot uninstall apps like FB, nextflix, youtube, koki etc. It reinstall itself after reboot when u uninstall it. 3)The screen resolution is only 1280x720. See photo. Will upgrading the firmware solve the problems? The firmware on my box is p281-userdebug7.1.2NHG47L20180407test-keys. Do anyone have a upgraded firmware for it? BTW how do I flash a new firmware for i98 Pro? I see there is a reset and update button at the bottom of the box but I don't know how to use it. Is it possible to save my existing firmware? Then if after flashing other firmware is not successful, I can restore it using the saved original firmware. Can anyone help me? Thanks in advance.
                  For those who own a i98 Pro, anyone able to run CCleaner or Speedtest by Ookla apps?? Mine no problem installing it. But when run it only open half screen. Totally can't be used. Confirmed apk working on other TV box so not apk problem. Anyone else having the same problem as me? Or anyone who has the same problem found a solution? Pls share. Thanks.
