/AndroidRuntime(6069): java.lang.UnsatisfiedLinkError: dalvik.system.PathClassLoader[DexPathList[[zip file "/system/priv-app/Phonesky/Phonesky.apk"],nativeLibraryDirectories=[/system/priv-app/Phonesky/lib/arm, /system/priv-app/Phonesky/Phonesky.apk!/lib/armeabi-v7a, /vendor/lib, /system/lib]]] couldn't find "libcronet.61.0.3163.81.so"
Just need a working ROM...
That's the crash I've found
Hi guys,
Just an update...
*touches wood*, I seem to have fixed the Play Store problem by manually (USB recovery menu) updating to 111M0, and via OTA, update to 113M0. Everything seems fine so far.
My male to male USB cable should be here tomorrow and over the weekend I will try updating to a Nougat rom, via the Burn Tool.
Thanks.
Originally posted by smrtprjcts View PostI'll try if I have some free time. But I'd like to understand how these apps are syncronized if they belong to each other. If you use the play to update the play only play apk is refreshed (if i'm right).
without it most can't work
It's responsible for what version of play store is dowoaded even if it's not compatible (crash)
Example: If you have the PlayServices for ATV installed it will download ATV play store then say incompatible when opened (unless config for ATV is used)
it used to be part of the framework way back but was changed to get older devices up to date with Google services without firmware updates.
There are normally a lot of variants of the same version
You need play store to update GooglePlaySevices
And need GooglePlayServives to update play storeLast edited by tillaz87; 03 November 2017, 00:42.
Ive had that same error, In my opinion Android 6 is much faster smoother on the GT1 than Android 7. I use the GT1_111M0 firmware for my box, you might have the AP6255 or the QCA9377 version. Once you have installed 111, when you first boot, and connect to wifi, go check for update, it will download 113 firmware which fixes the google play store error. About 27MB.
Originally posted by androidbill View PostIve had that same error, In my opinion Android 6 is much faster smoother on the GT1 than Android 7. I use the GT1_111M0 firmware for my box, you might have the AP6255 or the QCA9377 version. Once you have installed 111, when you first boot, and connect to wifi, go check for update, it will download 113 firmware which fixes the google play store error. About 27MB.
"if it ain't broke, don't fix it..." I'm staying put for now, absolutely no desire to try 7.1.
There are currently 2104 users online. 0 members and 2104 guests.
