2, no android 6 ROM.
AZW Mini M8S Pro-C
Originally posted by trebor View PostPop the lid and compare the two,Originally posted by AZW View Post
Cooling curve. Surfaces do not normally join because they used an old cooling plate.
The wi-fi antenna is poor, the signal strength is weak.
Interface 720p, it is impossible to use the browser normally, on a TV set of 50 "the font is stepped.
The rest is enough to read the theme with firmware (green stripes, support 4k 60fps).
Who wants to buy, better buy another device.
Will the money be returned to me?
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Originally posted by user_132 View Post
I bought. Compared. I recommend that no one buy this misery.
I'm getting 2 out of 4 bars for 5ghz AC wifi and I'm on the other side of my apt on a lower floor, which for 5ghz is typical. I get 10mbps with it. With 2.4ghz N wifi, I max out at 33mbps for what N typically can do (right next to router). And with ethernet I get 100% of my cable speeds.
After doing some stress tests I got 65 degrees for the SoC temps. And the UI looks fine to me.
I'm willing to concede that the UI may be 720p but I can't really tell. I installed an app called resolution changer and said my screen was 1920x1080 with 72 pixels for the bottom bar, and 240dpi.
Edit: I see other screen dpi programs peg it at 720p. It still seems to work just fine though, but since it can't do N64 better than my old RK3228, I'm going kodi with it, maybe also the gaming version.Last edited by sprockkets; 03 April 2018, 21:04.
There are currently 1399 users online. 1 members and 1398 guests.
